Is that tappable for the catch can fitting?
No. your truck should already have it@crazykid1994 With the 6.4 intake manifold, do you have to get an SRV controller, like MMX sells, in order for the active runners to work on the 5.7?
6.4L HEMI Intake Manifold SRV Controller by MMX
6.4L HEMI Intake Manifold SRV Controller by MMXwww.modernmusclextreme.com
Giggity!
So the active runners will automatically open and close without any additional parts or tuning? Do you know if the controller is native to the intake manifold or if the pcm is sending a signal to open or close? Because the 5.7 manifold doesn't come with active runners right? So there must be a passive controller on the 6.4 manifold activating the runners based on RPMs or something it is reading from the PCM?No. your truck should already have it
Do you happen to remember what the bolt size is for the EGR block off??
You da man, appreciate it!
