65rfe Transmisaion issues
rammagnum5.9L
2013 ram 1500 158k miles, new fluid and filters 20k miles ago, wot downshift below 70mph truck trys to grab 2nd then slips into 3/4 and locks in. Did a relearn on tcm same issues but now snaps your head back into 2nd gear anything under 1/2 throttle, 500 miles since relearn, valve body issue? Or 2nd gear shot and after relearn its trying to limit as much slip as possible? Just trying to figure out what the issue is as cheaply as possible no active or stored tcm codes before or after relearn. Looking for things to check data to monitor on a drive. Need to know if its something simple in valve body or if i need to get a core lined up to rebuild
JmGuTe
PA
Was the transmission serviced prior to that? Sounds like your classic "new fluid" slippery AF because you've removed all the metal particles with the old fluid.
