6inch lift questions
05singlecabHEMI
Lilburn,GA
Looking to get a 6inch suspension lift on my 2wd. And put on some 35s. Just had a few questions.
1: with the 2wd what would be the best thing to do to the front suspension? As in ball joints sway bar(same with the rear sway) would i have to get an extension? Never had a lift or seen anyone do it.
2: on 35s i know id be best for new gears, but will stock do for a while, not looking for performance.
Was gonna go tomorrow and get a quote before actually going througj with it. Thought yall might be able to give me some things ill be hearing about.
Thanks
-Nick
pavester
texas
fabtech 6" lift will have everything you need. just make sure you get shocks and all your suspension is in good shape. stock gears are fine, there will be more stress and you will def feel the loss of power and acceleration.... that being said, i ran a fabtech 6" with fabtech shocks and didnt change up any of my suspension. Also had stock gearing at 3.92 and gas mileage was about 9mpg all around alot less if i was romping on it.
