Frank Titus
I had a '16, & now a '23 Power Wagon (Rebel 2500). I guess the '23 would be a couple hundred pounds lighter without the front diff locker, & winch. Everything else is the same except the transmissions, 6 & 8 speed. Both had 4.10 gears. Really could not tell any difference in fuel mileage. The '16 would not tow anything in 6th without a lot of downshifting. It towed well in tow / haul, no 6th. The 8 speed knows what to do. You d on't really notice any gear changes; the ratios are closer together. I would like to test drive a Cummins with an 8 speed sometime. I've had a couple of Cummins with the automatics. I sure it would have less torque vibration with the 8 speed. However, I like the Hemi better, no vibration, & hundreds of pounds lighter on the front. Drives, & steers more like a 1500. Enjoy the 8 speed!
