6x9's or 6.5's
BradKnob
Prairieville, LA
Is that Audio Pipe and good? And I'm confused about what that actually does
4 channel interconnects?
When you asked how to hook up a multi channel amp to the 4600bt i was assuming you meant because the head unit has 3 output channels and the xapco has 6 input channels... the audio pipe just takes the 3 RCA out puts and turns it into 9
Big Boi
Big Boi
S. Fla
Gotcha. Audiopipe any good?
autokraftgt
Hemi 6.1
I have never heard Audiopipe so I can't comment.
I have heard many Zapco amps and they are nice amps
BradKnob
Prairieville, LA
I see a lot of the guys use audio pipe amps for budget SPL builds. So could be worse but not that great. To be able to split 3 channels into 9 and up the voltage output, id def give it a shot for $15.
Etroze86
Grand Forks ND
Audiopipe brand is usually for the folks that are just getting into this hobby without much of a budget. Are they bad? No I don't think so since their amps do close to rated for a low low price. Now accessories like the splitter are probably branded under different companies so audiopipe isn't the only one who has them. I'd look around or find reviews so you don't introduce a source of noise into what could be a very awesome stereo.
Big Boi
Big Boi
S. Fla
This is where I'm at guys. What do you think?
JL Audio C2-650
6 3/4 COMPONENT FRONT DOORS AND SAILS
JL Audio C2-350X*
3.5 DASH
JL Audio CS -690 TX
6X9 REAR DOORS
OR
Kicker 41KSS674*
Kicker 41KSC694
6X9 REAR DOORS
Kicker 41KSC354
3.5 DASH
OR
KICKER CS LINE
6X9 COMPONENTS FRONT DOOR AND SAILS
KICKER CS LINE
2 WAY 6X9 REAR DOORS
KICKER CS LINE
3.5s DASH
charonblk07
Calgary, Ab
F1-A forged 349ci
I personally like the JLs over the Kickers, and unless you're on a tight budget or just want loud avoid the CS line.
Etroze86
Grand Forks ND
Cause at one point or another they will all try to steal your heart lol.
Big Boi
Big Boi
S. Fla
I want to install everything at the same time or at least get the components, rcas, speaker wire and sound deadener. I gotta crunch the #'s again tonight. I think I can swing the amps, subs, and box too.
