C Rogers
So what is the end of story? Are we stuck with these defective transmissions?
Unfortunately until some mechanic figures it out, yes we are stuck with these.
My truck has been at the dealership nearly a month waiting on valve body with the same problem.
Well I wish they would admit that and change the driveshaft. They want to stick with their story that it's normal.That’s not a transmission issue from what I have read, it’s a driveshaft issue.
Does anyone know if this is a problem strictly with Hemi engines, or are the V6 Pentastar rams having this issue also?
My Chrysler 300 (2016) has these issues, too. It has the Pentastar V6/8SP combo. The 1st to 2nd gear shift when the transmission is cold is extremely weird, as it “shifts” and then the engine jumps around 1-2K RPM and then actually shifts into 2nd.
Sent from my iPhone XS Max using Tapatalk
Well that sucks. I was under the impression that the 8 speed trans was rock solid, excellent transmission. The more I read about ram trucks, the more I'm getting afraid to buy one.
It’s nothing to worry about, honestly. The 8SP is rock solid, just a few hiccups here and there.
Well you've come to the right place to hear about problems with any vehicle, an internet forum.I was under the impression that the 8 speed trans was rock solid, excellent transmission. The more I read about ram trucks, the more I'm getting afraid to buy one.
Considering you can probably read about more problems with RFE transmissions than the 8HP line-up on this forum even now.
Unlike the RFE, the 8HP design of trans is used not only in the FCA line up but also BMW, Audi, Bentley, Jaguar and Rolls Royce to name a few.. It is a very robust transmission design and probably one of the best features of a Ram truck.
There is one 8HP70 I know of that is over 600K miles(still going too) that most of that is while towing travel trailer and the only thing the owner has done is changed the fluid every 100K.
ZF the designers of the 8HP trans, suggest to change around 80K miles if I remember correctly, only FCA says filled for life.Good to know and hear about. You can change the fluid on these? I thought it was supposed to be a lifetime fluid, thus no real way to drain and replace?
I have a 2018 Pentastar 1500 with 3:21 rear end 26K miles and my 8 speed has been the smoothest shifting transmission I've ever driven. Knock on wood, I guess. I've commented to several people it seems like I have a race car driver doing manual shifts for me because it seems to lose RPMs just for a split second as it quickly changes gears. I've been very impressed with it!
