indept
- Sep 10, 2017
- 3,219
- 4,760
- Location
- South Jersey
- 2017
- Hemi 5.7L
I'm glad I have the maxcare lifetime warranty....
All right. I own a quick lube and have recently serviced a 2014 with 8 speed. Did not drop the pan. We have an exchange machine that is low pressure, uses trans pump mostly, is a 1 for 1 exchange, and is installed inline at the cooler line connection. Now, the fluid we use is a universal product that says is compatible with 68218925AA, the Mopar 8-9 speed fluid.
We did the service on 10-1. On 11-14 the customer went to the dealership stating having to try multiple tries to get into reverse. They diagnosed it as the selector switch. Had it replaced. On 11-19 supposedly has the switch replaced. On 12-11, the trans quits all together. This is all from the current repair order that I have of the truck. I am not 100% sure if all the services had the same customer concern.
So, after all this the dealership pulls some fluid out and says, no warranty, I used atf+4 and of course it a "sealed for life transmission". I file a claim with my insurance. Gave them the spec sheet showing compatibility. They deny the claim because we used "correct" fluid. Service manager says he "spoke" to the field rep and they are not going to do anything about it. Alright, I get it. I've done my research. I did the exact same procedure and fluid on my wife's durango and it's still running fine.
Contacted the manufacturer of the trans fluid and they keep saying its compatible. Now they want me to send a sample.
In the mean time, I have authorized the repairs for the truck and will be paying out of pocket. I will not become "that shop".
Not sure if this a rant or just a "have any of you guys seen something like this" advise kind of thing. I am sure I will be having to take this to court with the dealership. Everyone I've talked to keeps bringing up the Magnuson Moss Act with the warranty deal. Anyway, have a good weekend, folks.
The ram has that bypass valve the Weber video was referring to, correct? So we should perform this procedure TWICE to be sure the level is correct?
No way in hell is a tech going to do this as a troubleshooting step.
Who would be competent enough that you would trust to do this?
Sent from my Nexus 6P using Tapatalk
None of the video's I've seen lift the vehicle so that the transmission pan rail is level ,and the ZF instructions that come with a new transmission,are very specific about getting the pan rail level before checking the fluid.
I knew about that part (the service manual does make a note of it).
But the service manual does NOT mention the bypass valve at all. Nor does it say to perform the check again once the trans has gotten up to a temp high enough to close the bypass, which could show a different fluid level.
I am well aware. For $7,000 at the dealership, the ac work is included.BTW,you'll be on the hook for a new A/C condenser and A/C recharge,as the transmission cooler is part of the A/C condenser,and you'll never get all the ATF+4 flushed out of it,unless you flush a pile of new ZF 8/9 speed fluid through it,and in the long run,it'll be cheaper to replace the condenser,as from everything I've gathered up,there's a good chance you've screwed up all the seals in everything by using the wrong fluid
Just to expand on my question towards the start of this thread. Here are pics of the pan drain plug on the 8HP70. It does look like it can be removed and replaced, which like said, should make a cold spill and fill so simple a cave man could do it. No need to drop the pan. Every thread I've seen is with dropping the pan without first draining it. Dunno why this is.
The mileage at the time of the service was approx 86000. The fluid we use is red. Same as Valveoline MaxLife that I’ve see plenty of people use
Rather overkill to spend $7,000 on a brand new transmission for a 2014 truck with over 80,000 miles on it. Especially considering that you can buy one with less than half that mileage on it from a wrecking yard for from $500 up to around $800 for one with a quarter of that mileage on it and you can very likely have a transmission shop install it for around $300.00. Look here http://www.car-part.com/
Mopar1987, I know that you are a business owner and there's aspects of this that I'm sure I don't have a clue.
Thing is, why are you taking the blame for this? You used a fluid that is suitable for use in this application.
I would think it's in your best interest to be given proof that the fluid you used caused the failure. If the dealer is going by color alone, which I have a feeling they are, I'd hold my ground. I wouldn't be surprised if the dealer took your money and still got reimbursed in some way from FCA on top of it.
