smiley
- Apr 18, 2011
- 6,632
- 2,978
- Location
- Minot, ND
- 2014 Ram 2500 Crew
- 6.7L Cummins
Well I have had a total failure of my rear end. The carrier broke and sent crap all over and messed up the gear set with only 14k on it. It was an Auburn which I will be throwing into the garbage can. I think the Auburn was my issue as I got 100k out of it but it is gone!
I wanted to see what you all thought would be my options.
1) swap to another axle:
I have not liked the 9.25 and the pinion recall etc it has been garbage and I probably should have let Dodge buy it back.
2) rebuild again with the following parts
YG C9.25-456 - Yukon gear set
AK 6410 axle bearings and seals
913A368 Eaton Detroit Trutrac
Master kit with Koyo or Timken bearings.
Anyone swapped the 4th gen to a better/stronger rear axle?
