9005 LED's and DRL issues
MYMISSIONISFISHIN
Rochester, NH
Not quite sure what they are talking about. My '14 Ram has the reflector quad headlights. Guess I am not sure which are my DRL's , if I even have them. Think I do as I see them on the back of the vehicles ahead of me, but unsure where they are located in my headlights (Directionals, High Beam bulb etc). Reason for asking is I see where some of the LED 9005 Hi Beam bulbs, say they won't work if the DRL's also run off the High Beam bulb as well. Please explain to me , as I am looking at the LASFIT 9005 LED High Beam bulbs for my truck.
firebuff17
Ct
If you have quads.... your DRL is you high beam bulb at low power
mtnrider
Georgia
When in DRL mode the bulb runs at a lower voltage so most LED's will not work in that application. They need around 10v-13v dc (typically) so if the DRL voltage is 7.2v (which I believe it is) they will not work.
RAMTRPR
"Enjoy The Little Things"
Brentwood, CA
I have tried this and the led in fact does not work. My question is if I convert to projectors with the harness, does my DRL still use high beam at low power?
2009 QCRB 4WD - 4.56/Shorties/FMTB/Intake/Exhaust/6” on 35’s/lots more [emoji41]
