'96 Ram 1500 dies when slowing down or breaking
boochamp
Utah
5.9 L V8
Hey everyone! So this has been happening for about a month now and I've done just about everything I can think of to get it to stop. I've had this truck for just under a year now. In that time the fuel pump and filter have been replaced, all spark plugs and wires, rotor, alternator, air filter and last week I cleaned up the IAC valve and throttle body. It doesn't die EVERY single time I brake or come to a stop, but enough that it's a concern. Anyone have this happen before or have any suggestions or tips or anything else I can try? Thanks in advance! Have a good one!
bigdodge
Change the pcv valve. When coming to a stop idle is dependant on the valve opening to maintain idle. If it's sticking sometimes that would explain why it's not consistent. With my low vacuum cam I used to change mine every few months until I found a lighter valve.
Sent from my Pixel 4 XL using Tapatalk
boochamp
boochamp
Utah
5.9 L V8
I'll give that a try. Thank you
bigdodge
Cheap and easy. It should be in the passenger side valve cover with a hose connecting it to the valve body. No guarantee that is your problem but it's a problem I have run into. Hope that helps.
Old Sarge
Fresno Ca
Low trans fluid can cause that too. It can cause the converter to stay in lockup mode and then there's no slippage for the idle speed to keep it running.
ViolentMouse
San Diego
5.9 magnum
PCV valve (positive crankcase ventilation valve) is on the valve cover, This valve should not always be open at idle...it should be closed at idle (high vacuum) it should also be closed under high pressure. The PCV valve is designed to open at part throttle when vacuum signal is low and then it evacuates crankcase pressure into the intake manifold. A lot of us with big cams and low vacuum signal have issues with PCV valves being open at idle causing a massive vacuum leak.
Quick test on the pcv valve.... when the truck is idling, pull the valve out of the valve cover... if the idle changes the valve is working fine. if there is no change the valve likely needs to be replaced. Use only the dealership PCV valve. do not use the autoparts store one... the autoparts store ones do not close under pressure and will allow raw oil into the intake.
You can also just put a bolt in the pcv line for testing purposes....I have never seen a PCV valve good, bad, or totally broken cause anything more than oil consumption and a lean stumble at idle on a 5.9
Second test... with the truck idling and in park... press the brake.... if the idle changes, you might need a new brake booster. if it does not change then the booster is likely okay.
The brake booster has a vent inside the truck by the brake pedal, this is where the relief valve sits. usually if you have a bad diaphram in the brake booster when you lightly press the brake you can hear it hissing under the dash, it's a dead giveaway.
The IAC even if it is clean may be sticky... cheap enough test to just buy a new one... autoparts brand IAC's are fine.
if none of the above works.... try putting the transmission into neutral before slowing down and stopping, if your TCC solenoid is leaking or not sealing properly it could be keeping the torque converter clutch engaged and dragging the motor down with it. (very rare, but does happen, and not too hard to swap all your solenoids in a weekend.) I have also seen some transmissions that refuse to shift out of second if the fluid is very low. The inertia from braking causes the little fluid in the pan to slosh to the front of the pan and starve the transmission preventing fluid from moving in the correct passages to downshift, you can usually tell if this is the case because the truck will not down shift to first until you are completely stopped.
If you have access to a code reader that shows live data, you can look at your long term and short term fuel trims... if they are double digit positive numbers you have a vacuum leak somewhere. anything over 7 is a small leak, anything over 13 is a pretty massive leak. If you have not done your intake plenem gasket or put a hughes plenum pan on the intake, you can plug your PCV hose with a bolt, start up your truck and pull the pcv valve out of the intake... if you put your thumb over the hole in the valve cover and it tries to suck your thumb into the hole your plenum gasket is leaking internally.
Good luck hunting. Let us know what you find.
boochamp
boochamp
Utah
5.9 L V8
Thanks for the suggestions. I replaced the PCV valve yesterday and it stalled out twice today. I cleaned the IAC valve earlier but it still looked pretty rugged. Almost rusty. Could a brand new part there be the problem? I'll also try the brake booster test later today. Thanks for taking the time to post.
ViolentMouse
San Diego
5.9 magnum
If you have access to a scanner it will be of great help. You can view the fuel trims and IAC counts. That kind of data is super important in my line of work :)
