FullForceRam
- Joined
- Mar 27, 2016
- Posts
- 228
- Reaction score
- 133
- Location
- Brentwood, Ca
- Ram Year
- 2014
- Engine
- 5.7 Hemi 2WD Quad Cab
Would love your opinions.
I refilled my freon on my truck 2 years ago, last year it felt as thought the air not getting very cold when driving on the road so I decided to I replaced my AC compressor and evaporator off of my truck at a local automotive shop, had the service done and they filled it with freon to spec.
I picked up my truck, drove home with Ac and everything was fine. The next day I go to open my truck door and this weird chemical smell was in my truck. I cranked the engine on and turned the AC on and some strange plume of chemical mist came out of my vents for several seconds then it went away! I drove off and AC was not getting cold at all. I called up the shop that performed the service and he had never seen that. Mind you, the AC was working fine until then except the original AC motor was going bad had a minor leak hence why I chose to replace it. He refilled it with freon and sure enough a day later that weird mist and smell came out of my vents again...
I called him back and he said it could either try to seal the leak with a type of chemical and it could fix the issue or replace my heater core which he said was a much bigger job. Could my heater core be going bad?? Any truth to his possible fixes? or was something switched around on some hoses?
It heats up just fine in the winter and have had NO problems heating the interior, but when switched over to AC, no dice.
Any help would be greatly appreciated.
