a dumb question ...
Hemimania
Central NJ
I already have the rims chosen and now the tires. But a question about the air pressure. The tires are the same size but the website says the psi is 51. If the original pressure is 40 something (I think), when I get the new ones installed, will the truck know if there's a proven with air? Sorry for the dumb question. First time wanting dif tires.
Tonino
OC455
Central NY
You are wondering if the truck will show an error with the tire pressure monitor system if the pressure in the tires is higher than the recommended factory tire pressure? If that's the question no. I have my tire pressure set to 45psi with my Nitto G2's.
The tire pressure monitor system should only show you an issue with the tires if there is a difference between tire pressure in each tire.
