RamDiver
- Joined
- Jan 23, 2022
- Posts
- 5,582
- Reaction score
- 11,780
- Location
- Marlborough, Ontario Canada
- Ram Year
- 2021 DS
- Engine
- Hemi 5.7
Lights at shut off last about long enough for me to get out of the truck and close the garage door.
Haven't programmed the garage door opener, I still use the module.
It’s a two step process. I would start with the original remote with fresh batteries. You will need to clear the button in the vehicle as you cannot program on top of another button previously programmed. First you will program the remote to the vehicle. Second, you will match the vehicle to the opener (the unit hanging from the ceiling). Most opener manufacturers will have a toll free line and are able to walk you through the process. I recommend this as if you hit the wrong button somewhere during the process, they can get you situatedView attachment 577265
The Headlight off delay appears in 2 locations in settings.
According to the owners manual, a Uconnect 4C or 4C NAV has the options to set the Headlight off delay and the Headlight illumination on approach to 30, 60 or 90 seconds.
The programming of the HomeLink garage door opener should be in your owners manual, but if yours is worded like mine, it isn't too clearly presented. You may find some of the YouTube videos have a better explanation.
If you want to program the HomeLink openers, we can likely find online directions that are easier to understand or some members might be able to guide you. I have a video somewhere on the topic.
Found that this morning, and set it for 10 minutes , as shown .
2/3 of the time , still shuts off as soon as turn off engine .
Well , is it ?
As I mentioned, mine sometimes resets to 0 delay, then I set it back to 10 minutes.
Use the dial under the headlight knob, if you spin it all the way to the right you'll feel two detents and the interior lights turn on, one detent to the left and the dash doesn't dim at all but warning it will keep the dash and radio at full brightness and uses daytime colors which can be blinding at night. Spinning that knob to left fully everything is dimmed fully and the interior lights stay off even if the door is open.When Headlight comes on , the dash gets so dim , it might as well be blank .
You REALLY need to read through your owners manual a couple of times. It helps to do it while sitting in the car and playing with the various settings, buttons etc. The modern vehicles are VERY different than the ones we grew up with. As you are learning, they have a ton of features that are not all that easy to figure out. Best of luck with the new Pickup.It doesn't reset , it still says 10 min , it just shuts off anyway.
But since l found the hidden Accesory position, it's no biggie .
What is irksome , if a cloud passes over , the Automatic Headlight comes on . Still no big deal.
Settings > display on screen, there are buttons to adjust , but Pushing them , it won't change .
Out for the day w/ family in Biggfoot's '16 Yukon , will try it once home .Use the dial under the headlight knob, if you spin it all the way to the right you'll feel two detents and the interior lights turn on, one detent to the left and the dash doesn't dim at all but warning it will keep the dash and radio at full brightness and uses daytime colors which can be blinding at night. Spinning that knob to left fully everything is dimmed fully and the interior lights stay off even if the door is open.
And here I thought he was talking about a Ram...Out for the day w/ family in Biggfoot's '16 Yukon , will try it once home .
Opps ! In MRS Biggfoot's Yukon .And here I thought he was talki9ng about a Ram...![]()
Added- ( Which has only about half as much electronic crap . Plus the secret compartment behind the screen. )
I am Luddite. This ( '17 Laramie) is my first long term experience with new fangled push button instead of real key.
I don't want to start / have running engine to put windows up / down , or to listen to radio .
When l first got it , the radio would play for another 2 min or so after shutting off engine , before opening door , now , it's instant .
Is there some way to have equivalent of " Acc " , or am l stuck with screaming at clouds ?
I'm in the Ram , pulled up to the music venue checking back . I'll post pic either later tonight or in morning. ( Depending if wife & daughter show up to watch us play tonight)Post pictures, or it's not true.
