So... I figured out the problem why the DRL's didn't work... Now they work!
TAKE OFF THE DAMN PARKING BRAKE! LOL
I kept putting it in gear and the parking brake on to see if they were working! So get someone to tell you if they are on or use a mirror! LMAO
Below is the current configuration for the latest version of AlfaOBD V 2.2.0.0
Cust.Prog.Features: Daytime Running Lamps:
Select: Enabled
Cust.Set.Menu 1: Daytime Running Lights CSM Present
Select: Yes
ECUConfig 3: DRL Customer Setting Option Present
Select: Yes
CBC Features: DRL Configuration
Select: Optional DRL
CBC Features: DRL Lamp location Known working high beam, low beam, turn signal and fog lamp.
Select: Turn Signal
CBC Features: DRL Dropout Enabled
Select: Yes
CBC Features: LED Dedicated DRL Present
Select: No
