Adding stock subwoofer?
Mudder
Arkansas
So I realize everyone will say to add aftermarket but I’m mostly lazy and not interested in a ton of bass, just some filler.
Anyway, I have the stock 6 speaker system in my Express. I see the stock little subs going on eBay for like $130. Are they amplified or is that just the sub and box? I’ll include a pic for reference.
Also, I see they just have a wiring plug coming out of them. Would I need to purchase a separate harness to hook it up?
Thanks for the info!
The DodgeFather
I believe they do have a small alpine amp I can't remember
The DodgeFather
I have an extra one but idk what it would cost to ship
BadHabit2Break
Houston, Tx
3.6L
I have done this. I bought the OEM one on Ebay for $117 shipped.
Since you have the 6-speaker setup, you will need an amp to power it.
PartTimeHero
Oklahoma
Hemi 5.7 x 2
I wonder if it would be worth it to reinforce that factory box with fiberglass and add a 8" type-R
Edit: I know the sub will fit it has the same dimensions as the stock 8" After looking around I think line-x spray may be the best option to beef up the factory box strength without too much mess or modification. Fiberglass would work but I would have to drill some seep holes for the resin to flow through.
BadHabit2Break
Houston, Tx
3.6L
At that point I would just buy an aftermarket box.
But just wanting a "filler" sounds, the OEM is just fine.
PartTimeHero
Oklahoma
Hemi 5.7 x 2
My only thing is I would like to maintain the fold flat. I don't believe that's possible with a foxbox. It's no deal breaker either way. I'm fine with the current sub setup for now. But if I could reinforce the box and beef up the bass while keeping everything else in tact, it could be cool.
BadHabit2Break
Houston, Tx
3.6L
Thats another reason I went with the OEM box, i did not lose the fold flat.
Witch
Hemi 5.7 liter
I filled mine up with poly fill and upgraded the the Pioneer shallow mount, and am pushing it with a Rockford 250 watt mono Used the LC2i to get RCA's for the amp input
Mudder
Mudder
Arkansas
Well that’s disappointing for me. I was hoping those stock ones had a built in amp. I don’t really want to go to the hassle of adding an amp and all that Jazz. Ah well
Witch
Hemi 5.7 liter
How is the sound
Incredible , Takes the factory system to the next level
But do mistake it is not like having dual 10's.
it IMO adds just the right amount of low end that the factory system is not over whelmed by it
Thing I go everything amp, sub and power wire kit for like $ 225.00 out of pocket and did the install myself in 2 1/2 hours
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
you should try the OEM kicker upgrade to your normal speakers, if you are just wanting a much better bass response with good quality sound then this might put you where you want to be, i did this for my neighbor and he was beyond pleased, but that also gave him the itch to have big bass like i do so he had me install 2 10s in his truck and he is even more tickled now lol
HEMI_Finn
U.S. ARMY Veteran
Army
N.E. Ohio
Hurricane 3.0 HO
Did you consider the Kicker Hideaway?
Demon-HeMi
Houston
run for the hills on that one, i bought one and very quickly returned it...
amd im a very big kicker fan
HEMI_Finn
U.S. ARMY Veteran
Army
N.E. Ohio
Hurricane 3.0 HO
I was gonna consider it! What issues did you have with it?
Sent from my SM-G950U1 using Tapatalk
Demon-HeMi
Houston
sound quality just wasnt there, didnt even fill my single cab with bass, i got more out of my 6x9s
adrianp89
Tampa Bay, FL
How did you install it? I have done a ton and customers always love them. However I found that if you use a low-level input, it does not get as loud or sound as good (even when set up correctly).
