Mike Timmons
So I have a Beltech 2/4 drop & even after getting an alignment i still have a good bit of negative camber. Been looking at Adustable Upper Control Arms to correct issue. To me it looks like the bottom of wheel is kicked out more than stock & the top of wheel is where it was prior to kit. My concern is that once having the new control arms installed it will push the top of wheel outward which will make the entire wheel stick out more than it was stock. I do not want negative camber as I hate the way it looks & it's a daily driver. Any thoughts or opinions would appreciated.
