AF vs SilverBullet Showdown
AF or Silverbullet
  • AF
    Votes: 22 66.7%
  • Silverbullet
    Votes: 11 33.3%
  • Total voters
    33
shadow11
Banned
Houston TX
thanks that will prob end up happening. just did this first bc im the only one at my house and have no ride anywhere...
You may be able to get it stated by charging it but don't turn it off cause it won't start again.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Well guys sounds amazing! Hope you get the battery charged and the truck learns the new settings. Next custom tune and that thing will be a beast!
Bad Habit
Land O Lakes
Modded 4.7l
well it sounds good i hope you get everything right and fast, sucks aaron had to do a job and run, sounds kinda whorish...:) j/k aaron....damn good job though boys....
S
Silverbullet08
Persona Non Grata
got the battery. starts up good but the idleing is crappy. i assume i just need to drive it around?? also since the battery was reset is there a chance the tune was too? do i need to reload the tune or is it still on there
ramhunter9
P-Star Jeep Wrangler
well since we had no race and the poll is no good I figured i would vote anyway . WOW what a land slide !!!
ramhunter9
my vote counts like 50 times more than a normal voter:adminpower:
truckin151
2013 sport
You shouldn't have to reload the tune but you may as well, also pull the pcm fuse. Take it for a drive do some data logs (well whatever the sc can log) do some runs with the ac off and on since the ac bumps up the idle a little.
S
Silverbullet08
Persona Non Grata
just tried driving it around my neighborhood. it idles crazy and will stall out if i let off the gas or come to a stop. dont know what i need to do...
shadow11
Banned
Houston TX
I take it Aaron's truck didn't idle like that after he installed the cam in his truck?
S
Silverbullet08
Persona Non Grata
no he said hes would stall out. just the computer needs to learn what the changes are...
shadow11
Banned
Houston TX
Hmm i have no idea then. You think you just need to drive it more?
truckin151
2013 sport
PM hemifever and see what he says. Post a clip of the idle as it is now.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Are you getting any codes? I am sure you have done this already but check the wires near the exhaust, just make sure nothing has gotten hot.
Good luck..
