aftermarket radio harness for uconnect 5.0?
lilzilla2008
Which harness do i need for this to work properly? I can not find one anywhere that is a definite answer as to if it will work or not. I found answers for the 3.0 but nothing for the 5.0 which is what I have. Thanks!
1500ram12
5.9L Cummins
L
lilzilla2008
Thanks what you posted is what I ordered. Everything is set how I like and if it comes down to it me needing to change something then I'll plug the oem radio back in no big deal
adurm
FL
2015 RCSB
The truck will retain the settings even through a battery disconnect. Pull the memory fuse and that might be a different story.
Your USB ports might not work. There is an active thread about USB center console and possibly getting it to work.
