Air Lift 1000 with 6" lift
DohCanadian
Saskatchewan, Canada
So awhile back I bought the Airlift 1000 kit for my 2013 Ram 1500, and I recently got a 6" Rough Country lift kit installed on the truck.
So this summer I am going to get the Airlift installed but I think I am going to run into a problem. The RCX lift kit I have comes with coil spacers for the rear that have a bolt through the middle like so.
Now my question is how should I go about properly routing the air line? As I know it comes straight out the top middle and is going to have problems with that bolt being directly in the spot I need to route my cables.
Thanks
14hemiexpress
6.4l
Can you drill a hole in the side on the space place a rubber grommet in there and route it in through the side? I don't see a 1/4 hole or what ever size air line it uses causeing structural issues.
DohCanadian
DohCanadian
Yeah, that might be my only option. Drill a small hole right beside that bolt and put like a little 45 degree air fitting on the bag, just so I don't risk any kinks or anything.
TMFMK
