AlfaOBD
Moparman16
Northern Ontario
2013 Ram 1500
I sent an email to Alfaobd detailing what I am trying to do to see see if they may have any ideas what needs to be changed or if the functionality even exists
chrisbh17
FWIW on the 2016-2017 BCM control unit, "44-45 /44-46 w/sync"
On the 2013 and 2013-2017 control units, "BW4446 with synchro" is an option, so maybe thats the choice if you want 44-45 functionality.
mjf6175
NJ
cummins
@mjf6175 The one that you posted and Rick confirmed is the one I was referring to. Here is my current BCM config.
https://drive.google.com/open?id=15kpwkNE1LxJq2Cx4ySeQoXvGBlTDL7Eh
I still have not had the setting show up but I think I have another issue as to why I would not be getting it.
Ghost....in a couple of hours when I get a chance I will try the setting "Static&Dynamic". I looked quickly at your file and I have set one that you do not. I pasted it below, its in the beginning of the file:
LIN Module Customer Programmable Features:
Rear View Camera Static Grid Lines Enabled: Not set
Rear View Camera Dynamic Grid Lines Enabled: Set
I have both of these set. Now when I get to that last setting we will find out if it does anything.
Moparman16
Northern Ontario
2013 Ram 1500
That’s a great observation!
Moparman16
Northern Ontario
2013 Ram 1500
I’m pretty new to using alfaobd, should I be using the 2013 or 2013-2017 control unit when I make my changes?
Ghost_RAM
Ghost_RAM
VA
That is correct. I am pretty sure when you make changes on the 8.4 to set it as dynamic and you go into Alfa and check it says Dynamic enabled. If I were to select static on the 8.4 then log back into Alfa it would say Static enabled. If that makes sense. It changes depending on your settings.
scott116
Cummins 6.7
It makes sense. To be honest, I don't think I had everything set like this when I tried the CHMSL Line Menu. Of course, I also did not have the OEM Cargo cam installed either.
Edit: Ok, now I have to go try. Man it's
I enabled static and active, I tried with both checked and every other possible combination, key on engine running, truck in reverse... still no cargo cam line. My cargo cam line box stays checked when I first enable it with Alfa but if I uncheck it it won’t let me check it again.
mjf6175
NJ
cummins
Scott...well that is a bummer. I am going to try the same later just for the giggles. Check to make sure the settings below are also set, I highlighted them:
Customer Customisable Configuration set in the Body Computer:
Customer Programming Features:
Unlock all doors on 1st press: Set
Sound Horn on Lock: Set
Flash Lamps on Lock: Set
Headlamps on with Wipers: Set
Auto Lock: Set
Auto Unlock: Set
Door Alert Enable: Not set
Auto Wipers: Set
Illuminated Approach Time: 90 sec
Headlamp Delay Time: 60 sec
Accessory Delay Time: 300 sec
Ambient Dimmer Level: 1.00 %
Daytime Running Lamps: Set
EC Mirror Auto Dim: Set
PE Unlock All Doors or Approach Door: Not set
Accessory Delay Active: Not set
Remote lowering horn enabled: Not set
Remote lowering lights enabled: Not set
Sound Horn on Remote Start: Not set
Auto Relock: Set
Static Gridlines Enabled: Set
Dynamic Gridlines Enabled: Set
Sound Horn On Lock Status: Chirp on 2nd press
Customer Programming Switches:
Rear View Camera Dynamic Grid Lines Enabled: Not set
Rear View Camera Static Grid Lines Enabled: Set
Ghost_RAM
Ghost_RAM
VA
@mjf6175 When you look at your menu in the 8.4, are both of your grid lines (active and fixed) selected at the same time like scott16's image?
Don_T
In my truck I enabled Active+Static grid lines. I can only select one or the other. When I try to select the second option the one that is enabled turns off. Which ever option is selected works as it should.
justinkyleo
Waynesville, NC
Cummins 6.7
This may have already been covered, but has everyone actually connected the cargo camera to the linbus at the bcm to get the static line to display? The camera definitely has to be connected just like factory for the line to be projected to the camera.
Ricks Ram
My Lin is connected but unfortunately the setting to enable the cargo cam grid lines doesn't even show up to enable with the alpha tool on my 14.
Ghost_RAM
Ghost_RAM
VA
I can actually enable both and they will stay checked even after an engine cycle. Dynamic overrides static though.
mjf6175
NJ
cummins
Ghost....as of now I do not have the option "Parkview Backup Camera Fixed Guidelines" on the 8.4. I need to change the setting we talked about which was the "Static and Dynamic" setting. I currently only have it at Dynamic. Trying to get some time to go out and change it to see what happens.
scott116
Cummins 6.7
I think this may be my problem.... the infotainment harness only had power, ground and video. There was another wire coming off the harness but was not instructed to hook it to anything.
Ghost_RAM
Ghost_RAM
VA
I believe the consensus is that @justinkyleo hit the nail on the head.
Edit: Changing my settings back as it will do no good anyway.
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
FYI, I'm 99.9% sure that if you're using @DeereGuy 's cargo cam harness, the Lin Bus CBC signal is connected to the camera just like the factory trucks.
Anyone here in AlfaOBD land with a factory 2500/3500 cargo cam care to help by posting your config? & Do you have the cargo cam lines?
M² Mods.
