Sweet, sounds like just about anything you could want to add or mod can be unlocked.2013 Charger, enabled Sport Mode, Performance Pages, moved DRL's to turn signals, fogs on with High beam. Enabled installed reverse cam and door dimming mirror.
Clifford 15
are you saying it was not there after you read your bcm dump or you missed seeing it?
dss56, I tried to activate the VTA last September with an earlier version of AlfaOBD and I did not see that particular setting. In the new version the setting is: LIN and Misc-VTA System Present:Not set (my current setting). I will change it to VTA tomorrow to see what happens.
EDIT> Went out at 6:30 am to change "LIN and Misc-VTA System Present:". The actual setting was "No Security". Changed to "VTA" and now the red LED blinks as it should.
Now I need to figure out how to properly use the LOG update because it seems like I get the same log uploaded to G-Drive all the time. I will delete the current file in my Android device and see if I can get a new log with the current settings.
Before you delete it, scroll to the bottom of it. The log is a continually expanding file, all the new entries are just added to the bottom. It is not overwritten or re-created each time. (unless you actually do delete it, in which case it will be re-created)
-K
Just want to Thank all that have been in this thread. I have read darn near every post, all 600 pages and absorbed a ton of information. I bought AlfaOBD a OBDLink MX and a couple of KeyLessOption FOB's from Amazon and in about 5 minutes had 2 spare working FOBs for under $200.
Have some ideas of other mods to the Ram and will also look into what can be done on the Charger too![]()
I also have read all of his thread but my brain just will not absorb all of it. Do the FOBs you bought actually start and remote start the truck as well?
Will you send me the link to the FOBs you purchased?
Program your current key fob. It’ll come up as “failed, fob already programmed”, but if you get that far then you know the PIN is correct.How can I confirm the dealer gave me the correct pin code I would need if I ever change tire size? They didn't write anything down or print anything off just gave me the code
Dude you have been told over and over and over, go to the first post and click on the words “known working list” there are step by step directions. It only makes the thread longer when you keep asking the same question over and over and adds no value to those who are reading this.Ghost_RAM
Hi
I was hoping you or someone could further help me get this right.
I did purchase the AlfaOBD for pc and have it activated.
I should have the obd reader tomorrow by the tracking #
I need to know how to log or save my complete INFO if something happens making changes.
As I have posted Im only interested in 1 change adding the VAT alarm function.
I have a 2013 Ram Big horn with most every option remote start-moon roof-auto folding mirrors Alpine Stereo 8.3>uConnect>911 assist>Backup camera>and more.
Again just the alarm I want to activate.
Again thanks to all who have chimed in on my specific post with replies.
I thought having the info I need pre-hand would help me get ready.
thanks Bob in Boston Ma.
Click on his name and send him a message it’s that simple.Hey DUUUUUDE
I directed this to Ghost_RAM as he asked me to contact him and he would help me. Is that ok with you.
And I did read just need to make sure, is that a crime on here to ask
Sorry if you know it all as I don't.
So you dont have to answer my post any more if they bother you just log out or ignore my post.
Ok DUUUUUde
