AlfaOBD
Spud2388
Raleigh, NC
2017 Sport
It’s under CBC features in car configuration change called led front park/marker lamps. Good luck. I had the diode dynamics switchback boards and went through 5 sets of drivers they kept sending me before I threw in the towel on those things. I tried everything.
Mine are already set to led from the factory since I have the factory projectors. Thought about adding a PWM (canbus module) on the park lights before the Diode connection to see if it would regulate the voltage before the Diode module. We will see i guess.
Erikk
West TX
There seems to be a general agreement that prolonged idle of the Hemi leads to lifter/cam problems. The 13+ 6.4 Hemi in the 25-5500 trucks seem to have a high idle function like the 6.7 CTD.
Has anyone figured out if it can be activated using Alfa? I emailed Alexey twice about it but haven’t had any response.
Jimmy07
Hopefully you have better luck than I did. They had me trying every possible combination of cancellers, resistors, led settings, and every time I thought it was good to go, a week later the turn signal circuit in the driver would fail, or the park circuit in the driver would flicker and fail. It was always something.
Jimmy07
On the 6.4s, the high idle is only a feature for the cab and chassis trucks, but you would think it could be enabled on a regular 2500/3500. I looked before, but I don’t see anything resembling the feature in the alfa when connected to my truck.
Spud2388
Raleigh, NC
2017 Sport
Thanks for your help. I've already thought about using relays and just use the Diode module for the trigger wires, but if leds are flickering, just wondering if it would cause a relay to chatter. And obviously would need to look at output voltage for each. I'm sure they all don't get a constant 12v (or use the relays to power the Diode module, trigger from the factory wires (again, wondering out relay chatter), and let Diode module work as normal...:hmm:).
Jimmy07
When they worked flawlessly for me (for a week), I had the turns and parking lights set to LED, and I had the diode dynamics canbus cancellers wired into the factory wiring before the signal hit the switchback drivers. It was the passenger side turn signal that ended up failing inside the switchback driver. It could have been a fluke for me, but may be the solution for you.
Erikk
West TX
What year and engine is your truck?
I wonder if the trick is to activate pto or something like that? Maybe one thing opens up another set of options.
cwendel
US
Cummins 6.7
High idle uses the cruise control. My 2500 Diesel came with it activated. I do believe there is a setting in there for that. But you also need to have the parking brake on for it to work.
Sent from my Nokia 7.1 using Tapatalk
Eng50
Richmond, Va
Cummins 6.6l
Mine is factory set on 2500 2016 Diesel and I don't have to have parking brake set works fine without it..just my info..but yes hit cruise on then set and up she goes!
Sent from my ONEPLUS A6013 using Tapatalk
Erikk
West TX
I just came over from a 6.7ctd and on that one you didn’t need to have the parking brake set for it to work, but I haven’t tried it yet on the 6.4. I guess I’ll try that. Thanks
Erikk
West TX
I found a place in the engine section (2014 2500 6.4) on the Alfa that says “change rpm”. Is this referring to changing idle rpm, and is it permanent or a temporary “test “ type thing?
Mitchelljarvis
Nova Scotia, Canada
Anyone every mess with the speed govern. My truck tops out at 170kms (Canadian truck) any settings in Alfa to increase that? To perform such speeds legally of course...
Richmond2000
that is normal CUMMINS behaviour even SEMI trucks work that way
that might be Cummins and NOT RAM feature
1500ram12
5.9L Cummins
There is a way, I don't remember what had to be changed. I believe it was in the ecu settings. I know someone on cumminsforum figured it out. I don't recall if it was posted in the alphaobd thread or if it was a separate thread
Vshni
Canada
If I remember when I get home my rebel is set to 255kmh I could dump my settings and you could take a look if that would help but that wont be till next friday
Mitchelljarvis
Nova Scotia, Canada
My truck is set at 255km as well but still governs our at 170. Must be another setting somewheres else to change the govern
Mitchelljarvis
Nova Scotia, Canada
I think I found the forum you are talking about but they were only talking about changing the cruise control max speed
Being a 13 you can easily buy a tuner and basically delete the top speed governor.
PNUTLT1
California
Hopefully someone can answer this;
before i got the alfa, my cargo lights would stay on my ram when i was driving around.
I have bright red LEDs on the cargo, sorta like additional reverse parking/fog lights.
Now the cargo lights stay on only on park with the truck on.
If i have them on and put the truck on drive, they turn off.
Anyway to keep them on at all times?
