- Nov 3, 2011
- 8,366
- 7,529
- Location
- Houston, Texas
- 2017
- Hemi 5.7
I’ve never heard of this or had a problem with this. When the headlights come on in the “auto” setting, is determined by the amount of ambient light detected by the sun sensor in the middle of the dash by the bottom of the windshield, not the type of bulbs being used.
You don’t have to wait to turn the headlights on. The ballast is just sitting there waiting for power. Once power is supplied from the source, the ballast steps up the voltage to the igniter and excites the gases inside the lamp. You can take a 12v battery on the bench that is 90% discharged, hook it up to an HID kit, and the ballasts will still be able to ignite the bulbs. Why? Because ballasts can operate down to 9v, as long as there’s enough amps for the ballast to draw to fire the lamps. There is a couple seconds delay, but it’s not to turn the bulbs on. The bulbs come on immediately. It’s to get the lamps fired to full brightness. For this reason, I wouldn’t use them as high beams.
For our trucks, it’s not that the HIDs fail, but the fact that the low beam circuit uses PWM (pulse width modulation). This is the rapid throttling on and off of the 12v supply to the bulbs so that halogen bulbs will last longer. A ballast needs consistent 12v supply to fire the bulb, and when PWM is used, the ballast struggles to step up the voltage, and ultimately flickers and shuts off. The relay harness is used so that the ballast can get it’s consistent 12v straight from the battery, and use the low beam circuit as the trigger. These relay harnesses are subject to failure because PWM is still being used as the trigger, which creates relay chatter, which reduces the life of the relay itself.
So, all that being said, the AlfaOBD has the capability to shut off the PWM, therefore allowing any HID kit (even the cheap ones) to operate as designed for a long time.
That’s the best explanation I’ve read on here
