AlfaOBD
Cowdog
Santa Maria
One option is at the top and the others are closer to the bottom
Shugarrckbx
For certain there are 4 to enable for brake control, 3 for the one and I for the module..
Shugarrckbx
The issue I am having is that the custsetmenu options are not visibile in the AlfaOBD app. Once I get into Car Configuration Change there is no custsetmenu options to select from. I know which 4 I need to activate but cannot find them.
Maybe by chance it's being overlooked, I know for my self I've gone through the list back and forth and have over looked what I was looking for.
diboblo
California
Try connecting with a different MY PowerNet.
Shugarrckbx
Has any one enabled the aux switches with alpha? I installed the aux switch panel, all work with the key on, none work with the key off.(so they are all keyed with ignition] I saw on youtube enabling the aux switches with alpha in cust menu aux switches, I switched to present 1-4 . Not showing up in ra4 radio so I can program them for keyed or battery, but many YouTube videos show it being done and then showing up in the settings menu on the radio. Maybe I'm missing something?
Cowdog
Santa Maria
Your right the 4 th doesn’t say trailer it’s a abbreviation for something else but it’s the one that gets it on the Radio screen I think
HarvNC1
North Carolina
4.7L V8
Is there any list of all possible changes under car reconfiguration? I mean once in that area the list is long...
there are several just not the custsetmenu options like you need. Not for the trailer, windows, lights, backup...etc. there are a million other ones though
Shugarrckbx
The cust set menu you need for the trailer is near the bottom if the list, do you see the one for the module, it will be up further in the list not under those..
Shugarrckbx
Its capable of it... did you try going in using a differant power net, like my 2014, or my 2015 instead of power net 13-17 or Visa versa...
Jimmy07
Tried going thru the entire list. No custsetmenu options whatsoever. Not for anything. It had all the wiring for the brake controller so I imagine it’s capable of it
If you have a 2013, the CustSetMenu settings don’t populate. They are not in the list for MY2013, MY2013 var 1., or MY2013-2017. You’ll have to see if you can connect as a MY2014 or higher from the body computer list. If that doesn’t work, you’ll have to try the windows version.
HarvNC1
North Carolina
4.7L V8
I do not see any of them. Need to do the backup camera too. I did change the radio out from an RA2 to the RA3 a few years back. Could that have anything to do with it?
HarvNC1
North Carolina
4.7L V8
I have both versions. I will try from my surface tomorrow and see if I can connect thru the 2014. I’ve tried every which way with the android.
Shugarrckbx
Radio should not affect it, I have a 2014 that had the ra1, I now have ra4 with nav, and it's not causing any issues, what year is your truck?
kad
Hudson Valley, NY
5.7L HEMI
Anyone experienced an issue where the AlfaOBD android app refuses to save the proper System ID / System Status Log? I can Read the System ID / System Status in the app and it's correct, but when i go to save the file to my drive, i keep getting a log from February 28th for a truck I never scanned. I tried clearing the app cache and user data, no dice, I tried uninstalling and reinstalling the app, still keeps uploading the same incorrect log from a 2016 Laramie to my drive.
Alpha adds all new data to the bottom of the file (it's continuous, each output gets added to the bottom). Did you scroll to the bottom of the file and check there?
-K
Shugarrckbx
Ok, I know certain things with the 13 were different from 14, weird.. I would do like Jimmy07 said and try that. I cant get my auxillary switches to show up in my radio settings even tho I enabled them through alpha and they are present. But guys with 2015 are able too, so I'm having a issue too.
Mrmagoolin
Pendleton OR.
Cummins 6.7
I do not think that they show up in a 14 on the radio. I have a 14 and the cust set do NOT show up. I was able to set them in alfa. It is under Cusst Prog Feat-CBC AUX "1" power managed. Then choose battery or ignition. And you can also set them for momentary or on/off or I believe remember last state.
