- Jan 8, 2015
- 9,103
- 4,794
- Location
- St. Louis
- 2014
- 3.6 Pentastar
What color is the lower brow when on in DRL?I installed Alpharex G2 Pro headlights and replace the halogen low beams with LEDs. They work ok. However, I also installed the DRL wiring from M2Mods to enable the dedicated DRL function, rather than using the supplied harness and tapping into the F66 fuse. I only want the DRLs to come on while in R/N/P.
FWIW, I did connect the supplied cable into F66 and they do work that way, but they come on whenever the engine is on, which is too often.
I programmed the following into AlphaOBD and I CAN see the DRL option in my UConnect screen now (in the lights section). However, the DRL 'high brow' LED lights aren't coming on.
CBC Features: DRL Configuration - Optional DRL
CBC Features: DRL Lamp Location - Dedicated
CBC Features: LED Dedicated DRL Present - Yes
CBC Features: ECUConfig3: DRL Customer Settings Option Present - Yes
CBC Features: LED Low Beam Lamps Present - Yes
Cust.Set.Menu 1: Daytime running lights CSM Present - Yes
