AlfaOBD
WWW1
IN
I have a '24 3500 tradesman. I swapped out the front power heated and cooled memory seats from a Laramie. I changed CSWM(HSM) from deactivated to active MSM from deactivated to active and Heated seats present from deactivated to active in JSCAN. The passenger seat worked ok but the drives did not work the first day. Next day i bought AlfaOBD and loaded it on my tablet. Went to the truck and started to hook it up when i turned the truck on the rear camera and 2 other icons showed up on the radio then the 2 other icons disappeared. I only got a quick glance at them and they looked to say something like heated and cooled. after that the drivers seat would move. I finished hooking up AlfaOBD to the truck and changing all the seat info that Jimmy07 had posted in a different forum. after a few days no soft buttons on the radio but i can turn on the heaters and cooling fans with Alfa. Just trying to figure out how to get the soft buttons to come back on the radio and stay on. Any help would be greatly appreciated!
Ramster2015
NY
I have been searching but no luck as of yet. I have the auxiliary panel from 4th gen electronics. When I first installed it I had the base cluster and had the options for programing them on the dash. But I upgraded to the 7inch cluster and lost the options. I have tried turning it off and back on but no change. Anyone have any ideas or know of a thread that discuses this?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Are the options in the radio too? What radio do you have?
dodj
Canada
About to make the change from a traditional code reader to alpha obd and bt dongle. Is the security bypass cable required if you only intend to read information? I'm not interested in changing parameters at this point. Just live data.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I don't believe so. I just read all modules on my Wife's 2022 Pacifica without the bypass installed.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
If you are only scanning for codes and not changing any parameters, you don't need the AlfaOBD program. Alfa is specifically designed to manipulate the programming and run numerous test sequences on Mopar vehicles.
There are a ton of code reader / reset apps out there. The OBDLink MX+ comes with a great app for that and TorquePro seems to be a favorite that can be had super cheap for android..
ToxicFire
Canada
hey anyone own a 21+ challenger with alfa i have a few questions if you can pm me that be great!
dodj
Canada
I have a regular code reader but was interested in live data graphing. Alpha was referenced the most for this purpose so I thought it was the better option?
Wow. On here since 2018 and only 2 posts.... guess I spend more time on the cummins forum. I'll have to hand around a little more.....
Matchrocket
Mountains of Idaho
6.7 HO
New to AlphaODB. Digging around in the options, and I found a PIN in the RF_HUB. Is this is the PIN needed to program KEY FOB's??
Connect to Radio Frequency HUB
Scroll down to Read PIN
Start
Get PIN #.
AI Summary on this command gave me this. Assuming I DON'T need to hassle the dealer for a PIN?
My Truck is 17'
RamDiver
Marlborough, Ontario Canada
2021 DS
Start
Get PIN #.
My Truck is 17'
Yes, this is the PIN required to create FOBs.
Just an FYI, on some of the more recent vehicles, I've read that they have a 5-digit PIN.
Also, I've heard talk of a 5-digit rolling code for some newer vehicles, but this is second-hand information that I've read without supporting evidence, such as any specifics of programming FOBs.
Be sure to read up on backing up your current OE BCM configuration before making any tweaks.
And, welcome.gif to Ram Forum. :cool:
PA Ram
Quakertown, PA
Start
Get PIN #.
My Truck is 17'
Yes the pin is for programming new Fobs.
Matchrocket
Mountains of Idaho
6.7 HO
And, View attachment 570751 to Ram Forum. :cool:
First thing I did was download the Configuration log and did a Configbackup then pushed to the cloud :)
Matchrocket
Mountains of Idaho
6.7 HO
RamDiver
2021 DS
Thanks.
Assuming #4 results in this file? (Snapshot)
You're most welcome.
That would be it, good work.
You're already ahead of many new users. :cool:
Also, it would be prudent to limit the number of changes you make during each session.
Create a new backup and a readable BCM config record after every change session.
I keep a written log file with the current settings and notes on the results of failed tweaks.
Several of the tweaks don't function, such as Global Windows Up.
Some of the tweaks have unexpected results like killing the electronic power steering (EPS), so I wouldn't plan any big tweak sessions before a family road trip. :cool:
Sometimes, when I just want to get something new set before heading out, I pack my PC and OBD interface with me so if something silly happens, I can undo that last tweak. :cool:
Matchrocket
Mountains of Idaho
6.7 HO
Matchrocket
Mountains of Idaho
6.7 HO
I found a bug possibly when creating human readable Body Control Module config and status reports after changes are made. I created an initial HEX and text system/status file when I first installed the application. Since then, and after making a few changes to the truck, each subsequent creation of the file would have the EXACT same time stamp of the original I first created and the changes I made would not be represented. This is when the file would be viewed on my phone or pushed to the cloud (Google Drive).
I deleted all the files using the Manage ODB files icon in the app, and created a new text system/status file and got the same result. I would up having to clear the applications cache and stored data in Android for me to get an updated / correct system status file with a correct time/date stamp, and that reflected recent changes.
Anyone else seen this before before?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
It's a rolling log so it grows longer with each additional read appended to the tail end. Did you keep scrolling?
Matchrocket
Mountains of Idaho
6.7 HO
I was using file comparison tools to check deltas, came up no deltas every time, and file sizes are exactly the same each time. If it's supposed to be rolling, then that is also not happening correctly. I don't see an option to turn that on/off in the app.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Maybe a permissions issue? Couldn't write to the same file after initial creation?
