AlfaOBD
CincyCuda68
Ohio
I dont know I will have to check in the morning
thanks for the tip
Did you enable the approach lights with Alfa? Some settings take a while to show up, I’ve had to wait up to an hour for some of my changes to “sync”. I’ve read some that have had things show up the next day.
If it was already enabled they should work, I agree that it would be unlikely that both are out, but not impossible.
dss56
Boston
No I did not activate with Alfa. I checked the lights this morning and no way for me to turn on, i tried the keyfob and the inside light dimmer. The amber lights work for the directional's but not under neath for the white lights to work.
here is the door log after activating my alarm. Shows its set
2013 big horn
Doors Configuration:
Global Up: Not set
Global Down: Not set
Sun Shade: Not set
Folding mirrors present: Set
Heated Mirrors: Set
Mirror turn signals present: Set
Driver Memory Mirrors Present: Not set
Passenger Memory Mirror Present: Not set
Electro-chromatic driver mirror present: Set
Electro-chromatic passenger mirror present: Not set
Tow Mirror Present: Not set
Blindspot Mirror Present: Not set
Mirror Approach Lights Present: Set
Door map pocket LED present (Ambient Lights): Not set
Door Courtesy Lamps Present: Not set
Window Motor Type: Not set
Window Hall Sensors Present: Set
Door handle LED present (Ambient Lights): Not set
Frameless Window Present: Not set
Ghost_RAM
Ghost_RAM
VA
2013 big horn
Global Up: Not set
Sun Shade: Not set
Heated Mirrors: Set
Your settings are correct for the approach lights.
dss56
Boston
Thanks Ghost_Ram.
Im not worried about the mirror lights in time I will find out why they dont work. But glad I was able to get the alarm to work.
wedge775
Phenix City, AL
I did I v6 efan swap in my 2010 1500. My tuner does not give me the option to change my fan temp. Can I change it using AlfaOBD?
dss56
Boston
I think it starts at yr 2013-2018 for the AlfaOBD
first page
Please Read!!!
Supported years: 2013 to 2018
Make a backup of your original BCM configuration before making any changes. While we have a few BCM configs to compare with, there is nothing like comparing to your own pre-changes.
dss56
Boston
I did just got the AlfaOBD and the OBD reader and worked ok with my laptop windows 7.
Can some of the members post a good android tablet they had good results with. Might want to go that route also. Dont need android phones just a android tablet if that will work good also.
thanks
1500ram12
5.9L Cummins
thanks
I use the $50 Amazon Kindle fire 7. Downloaded the play store and it works just fine. I only use it for alphaobd
1500ram12
5.9L Cummins
There is a either 06-12 or 09-12 (don't remember which) alphaobd thread. Try asking there
gapi
Georgia
HEMI 5.7
thanks
I use a Nexus 7 WiFi, it does well.
6speedcummins
N. Dinwiddie, VA
Is there a way to activate the elevated idle function with the cruise control, like the trucks that have a PTO? I see settings for it but haven't had any luck. I'd like to be able to bump the idle up on the fly.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Can't locate the thread about adding power fold/memory mirrors but there's a deal on a set of non tow, power fold memory mirrors on LetGo in Spartanburg SC (near me) for $200.
Info/link added to eBay/classified section for those interested.
M² Mods.
akordboy
US
Along with the trailer select, name and type set to yes, is this the other setting for the trailer brake controller? TIA3ecd44fbcf0f69335f936fa867a41e3a.jpg
Richmond2000
I would LOVE to have that on a 1/2 tonner
I saw a VID for a JEEP programmer that has idle rpm change and can "idle up" tro at least 1600 RPM on a WRANGLER
software was obd Jscan I know the Wrangler are NON "powernet" so like a PRE 13 RAM the Jscan VID the guy does it "live" with it running and it responds while running
Ghost_RAM
Ghost_RAM
VA
GordDavey
Toronto, Ontario
Sorry to ask this once again, but I never got any responses.
Does anyone have a backup of their AlfaODB "Engine" Config settings (PCM) for a truck with a 6-speed transmission they can share with me? Please ?
Woody1
Idaho
I was causing through the engine computer, and saw something along the lines of "engine de-soot".
Is that running a manual regen?
2018 Ram 2500 Cummins
Iflyabeech
Mission, TX
2015 Ram 1500 4x4 Outdoorsman Crewcab
Ecodiesel 3.0
I'm trying to clear this code:
Implausible Data Received from AHBM
Last test completed unsuccessfully
Error present
Failure warning lamp 'ON': Not requested​
I have turned off all the ahbm settings I can find using ahbm or high beam from search terms.. Can anyone help?
I was trying to enable it before I realized you had to have the modules present.. Thanks!
Also any tips to get the HVAC config to change to Single Zone Auto, I changed it to multi zone Auto, but I can't seem to get it to change back to any single zone....
So it has been since last Wednesday I have had the HVAC config changes to Single Zone ATC. My truck came as single zone mtc, and I changed it to multi zone ATC.. I cannot get it to change back to Single zone ATC or MTC. It is stuck on multi zone ATC..It works ok, just the second zone does nothing. I'd like to have it behave correctly. Any tips on getting the single zone atc to take?
akordboy
US
Fuguuvhitch
