AlfaOBD
kad
Hudson Valley, NY
5.7L HEMI
I did just got the AlfaOBD and the OBD reader and worked ok with my laptop windows 7.
Can some of the members post a good android tablet they had good results with. Might want to go that route also. Dont need android phones just a android tablet if that will work good also.
thanks
I use a Samsung Tab A, 8", works just fine.
-K
Ghost_RAM
Ghost_RAM
VA
So it has been since last Wednesday I have had the HVAC config changes to Single Zone ATC. My truck came as single zone mtc, and I changed it to multi zone ATC.. I cannot get it to change back to Single zone ATC or MTC. It is stuck on multi zone ATC..It works ok, just the second zone does nothing. I'd like to have it behave correctly. Any tips on getting the single zone atc to take?
I went back an read your posts and want to make sure you understand that the AHBM doesn't have anything to do with your HVAC. AHBM is auto high beam module which relates to the mirrors sensor to trigger the high beams on and off.
The HVAC settings are located in vehicle config 3. Did you follow the steps below? Also, the dual zone ATC won't do anything if your truck came equipped with single zone MTC. How did your truck come configured (radio/HVAC)? The correct procedure on changing from single zone MTC to single zone ATC are as follows.
Vehicle Configuration 3: HVAC Configuration:
Select:
Dual Zone ATC
Disconnect AlfaOBD app & shut off the truck for a few minutes and you must wait for the Dual Temp sliders to display on the 8.4 radio before proceeding with single zone ATC change.
(Battery disconnect between can speed up the radio/BCM reset for changes, especially with a UAx radio)
Select:
Single Zone ATC
Iflyabeech
Mission, TX
2015 Ram 1500 4x4 Outdoorsman Crewcab
Ecodiesel 3.0
Select:
Dual Zone ATC
Select:
Single Zone ATC
Yes I asked two different questions in Hugh beams and ac configuration.
Truck came with 8.4ra3. I have a Kenwood 9903 with idatalink maestro now.. hvac was single zone mct. It switches directly to the multi zone atc and it works but I can switch to single zone atc or mtc.
It’s been sitting on single zone atc since the 21st and hasn’t changed. I just changed it to the factory setting of single zone mtc to see if that works...
Ghost_RAM
Ghost_RAM
VA
Did you install anything before making changes in Alfa for the ATC settings? If your truck came with single zone MTC then you would select single zone ATC but you have to follow the procedures outlined in the known working list I posted above.
akordboy
US
All of the ones I listed from the known working list.
I'm just gonna assume that's the correct one since I haven't seen a setting that just says "ITBM/HWM integrated trailer brake module". Thanks!
Ghost_RAM
Ghost_RAM
VA
If it does take, let the truck rest for a while with the fob away from and the truck locked up for a little while. It can take some time for the settings to take and some have mistakenly tried to set again thinking it did not work for them.
Jimmy07
With an aftermarket radio and the maestro, you can only set it to “dual zone ATC” to have it work properly. I have the same set up, and if you try to go to “ATC single zone”, it will glitch out. This is because the maestro is flashed to a Ram truck, and all it knows the ram to have is either single mtc, dual mtc, or dual ATC.
Ghost_RAM
Ghost_RAM
VA
Thank you for clearing that up Jimmy! Adding this comment to the known working sheet.
Iflyabeech
Mission, TX
Ecodiesel 3.0
I changed it back to single zone mtc but now it is still in multi zone atc and I can’t adjust the temperature. I don’t know what the dual sliders are. I’ve never seen them
Ghost_RAM
Ghost_RAM
VA
In case you missed it.
https://www.ramforum.com/posts/1984145/
Let the truck rest for a while then go back in and select dual zone ATC per Jimmy's instruction.
Ricks Ram
I just saw this post and we had the same thing happen as Jimmy07. We flashed the dual zone ATC and it worked fine to a Pioneer head unit hooked up to a maestro. When we switched to single zone ATC it did not work we had no control over the temperature select buttons or fan control. We put it back to dual zone ATC it worked fine again of course the dual zone does not function.
kylant
Bend
Cummins
can somebody please post a step by step instruction template on how to enable drls for projector headlights please?
the step by steps posted so far are confusing and don't quite match what I am seeing on alfa. seems like there are more steps than what has been posted.
it looks like you have to enable them in car configuration change and program custom features, correct?
thanks
1500ram12
5.9L Cummins
thanks
Where do you want to activate them? Look for my name in post 1 and there is a Google drive link with step by step instructions with pictures
kylant
Bend
Cummins
thanks.
that helps.
so first i need to enable them in program custom features.
then go to car configuration change and go through each parameter.
Ram-engineer
hemi 6.4
So has anyone figured out how to get the windows to roll back up with the key fob after its enabled?
Sent from my SM-N950U using Tapatalk
1500ram12
5.9L Cummins
thanks.
that helps.
Just follow those and you'll be fine. If you have the 5.0/8.4 radio it could take up to 24 hour's for the setting in the radio to appear
Ricks Ram
No Several have tried in a doesn't work. We are assuming it's because Chrysler disabled the feature for safety reasons. Only Global Down works at this time.
1500ram12
5.9L Cummins
Not with alphaobd. Since it wasn't a feature that dodge/ram offered in our trucks we can't get it to work. It may be a feature in a different product line with a different door module that potentially could cross over in work but no one has posted anything about it
Ram-engineer
hemi 6.4
I think it would be more useful to be able to make them up and down
Bettula
