Mrmagoolin
- Joined
- Oct 25, 2018
- Posts
- 103
- Reaction score
- 31
- Location
- Pendleton OR.
- Ram Year
- 2014
- Engine
- Cummins 6.7
Anyone having trouble with Alfa 2192 on android not opening up? Mine goes to a white screen and nothing happens.
I'm on version 2.1.9.3 as the most current, try an update
I have and the APK site won't open either. Also 2192 was opening for me.
It had slots for two cables coming out of mirrors, thought I didn't need to buy modules.Did you change your driver and passenger door modules? If not that's your problem.
Have tried that. I can delete and load version 2176 which is the next most recent I have downloaded.Maybe try delete and reload?
I believe the issue is that it needs to be a 2016 and up radio to get the cargo camera button. Have you tried setting the cargo camera settings back to what they were before you changed it?Hi all,
I have a 2015 Laramie 1500 and upon trying to add a cargo camera settings, it removed the trigger to show the rear view camera when going into reverse. It also will not show as an option on the 8.4 screen (either cargo or reverse).
So now I can't view the camera at all, no matter what I do. I backed up my datalog, but when comparing, I don't show any differences so I'm not sure how to backtrack.
Can someone kindly advise why this might be the case? & if there is no answer, is their someone that can help me reverse my settings back to what they were?
^^^^ this.I believe the issue is that it needs to be a 2016 and up radio to get the cargo camera button. Have you tried setting the cargo camera settings back to what they were before you changed it?
Ok, what are these set to?The genius that I am did not keep track of those changes. I can try to revert some back, but it’d be a guessing game at this point.
VehConfig 1 - CHMSL Camera - YES
CBC Features - LED CHMSL Lamp Present - YES
You might be able to add the dedicated DRL circuits to your truck. There is a plug under the fuse box that you need to check for these two circuits:I'm going to attempt DRL on my 2018 Tradesman crew cab with 7 inch evic. I purchased some Spyder LED headlights with the bar around them. I wired the LED bar to the parking light per the directions. I saw under CBC Features DRL location there is a choice for SRT Light Bar DRL. I'm assuming that doesn't have anything to do with a signal to the parking light and the only way to do this would be to wire into something else?
Appreciate any help or wisdom.
AlfaOBD doesn’t refer to options by sales code. GXM sales code is for remote keyless entry, therefore, you would enable remote keyless entry and reset the win module.View attachment 219172 View attachment 219173
2011 Ram 1500 Crew Cab SLT
I’m trying to program some key fobiks for my truck as I didn’t get any when purchased. (Used).
AlfaOBD & OBDlink MX
I “successfully” programmed two fobiks that now work to start the vehicle, but none of the buttons work. No lock or unlock.
Everything I read says I need to add code GXM, but I don’t see that option anywhere. Under configurations I found the option to turn on RKE Remote Keyless Entry, but nothing for GXM.
The build sheet shows:
“Sentry Key Theft Deterrent System”
Do I have the wrong key fobiks?
Do I have the wrong WIN Module? P05026533A1
Or is there an antenna that plugs into the WIN that I need to add?
Connect to the win module and reset win configuration.Ok, maybe my problem is I didn’t reset the WIN afterwords. What are the steps for that?
For the auto folds- He did say he would check back into it to see if 1)the setting even works on a grand Cherokee, and 2)if it’s a capability issue with the door modules or bcm.
