AlfaOBD
Caterpillar
France
Rebel 2016
Big thank you Jimmy07 I will wait it is not available at the moment
Gus T
So cal
That one might not show up depending what year bcm it connects as. You can use the windows version to pull up the 2018 settings list. Otherwise, just try the VehConfig 3 setting.
So I was able to change the vehconfig 3. Now the fuel gauge reads a little under 3/4 tank. I know that’s not right since I just filled the tank to capacity. Any other thoughts?
ManualCummins
Cummins 6.7
Anybody that needs good working keys
I buy all my keys from Northcoast keyless if you leave A five star review they will send you a 20% off coupon within a few Minutes
I can get an OEM non-branded key regular tip style for about 30 bucks
Caterpillar
France
Rebel 2016
If you can give me link for fob 5 functions
Thank you
Tepco
North Carolina
I have a 2016 ProMaster City it says I need the yellow connector. I thought with the LinkMx+ you didn't need additional connectors, guess I read it wrong.
So I need a yellow connector in the states, the alphaobd is causing codes as it's trying to connect (or I'm trying to figure out the 5 digit "card code"
TonyMM
2016 RAM 1500 CC 6"4 4X4
Hi , thanks for your answers ,, I want to change because here in Sweden the RAM will be
registered as a heavy vehicle ,, and heavy vehicles here are not allowed to have a top speed for more then 90km/h .
as soon as the registration process is done I would remove the speed limit ,, at least that was my idea
Wouldn’t a 90km sticker on the back be also ok?
MartyZ
Lake Orion, MI
2500 5.7l Hemi
I saw somewhere in the settings an option for "Fuel Tank Capacity", Maybe the configuration change changed how many gallons it thinks you have?
RLT1
FL
As I understand it, nothing should be touched as far as things changed. The PCM items are different than the Body Control Module.
I was thinking that but wanted to confirm. Actually now switching out the Pulsar for a custom tune. Just not sure who to go with. I have vararam, pedal commander, changes out the muffler, added exhaust cutout, 190 tstat, removed the middle louvers up front and hellcat wheels with 305 Toyos. Planning on long tubes, larger throttle body, e-fan and possible super charger down the road. Any suggestions are appreciated.
Gus T
So cal
Yep, that’s what I changed to reflect the bigger tank. I ended up changing it back to the liters the OEM tank had. I reached out to titan tanks and s&b and they don’t have a fix for it is what they said.
Roberfems
Denvar
V8
I have the same issue with my custom alpharex g1 headlights. I haven't found a solution yet
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
I'm having a similar issue on my '03 2500 with HIDs I got from xenonpro.com and they told me that I will need to buy more aggressive capacitors such as these ones from amazon. From my research, the hyper flash and DRL are closely related. DRLs operate kind of like dimmers and certain bulbs/headlights require a constant (non-variable) power flow. Based on the comments i'm reading on the amazon reviews it seems like it could fix your issue on your AlphaRex headlights
popcenator
Omaha, NE
I'm partial to Jay Greene tunes myself, it's what I'm running on my 5th gen and what I ran on my 4th gen.
Sent from my SM-N986U using Tapatalk
marine6212
Does anyone know how to turn AUTO Headlights back on with Alpha Obd?
RLT1
FL
Great thanks
That’s what I was thinking
A lot of good reviews
marine6212
Auto headlights. I activated the DRL's and my auto headlights quit working. I turned DRL's off and still no auto headlights!
Auto headlights or Auto high beam, as in smart beam. Just want to make sure of what you're looking to accomplish before providing any information.
lpennock
Phoenix, AZ
5.9L & 6.7L Cummins
Did you accidentally set VehConfig 3: Auto Headlight feature present to no?
Sent from my SM-T500 using Tapatalk
marine6212
I'll double check today and get back with you!Screenshot_20210417-042822_AlfaOBD.jpg Screenshot_20210417-042924_AlfaOBD.jpg Screenshot_20210417-042822_AlfaOBD.jpg Screenshot_20210417-042924_AlfaOBD.jpg Screenshot_20210417-043300_AlfaOBD.jpg
Caterpillar
France
Rebel 2016
Thank you Manuel but everyone here has bought some and there is none !!!!!!! I will have to wait
Lowrider357
