AlfaOBD
Evguy1
Errington BC
2014 RAM1500
Cummins ISB 170
I'm desperately trying to find someone who can tell me what this should read on a RUNNING 2014 Ram 1500 Hemi:
Crank unlock in run mode:Crank Has Not Unlocked In Run Mode
Its in: engine "read system status"
Anyone have a couple of minutes to help with this?
miles01
Alberta
Iv'e read everything I can find on seat belts in this thread, and I'm not seeing anything definitive. Can anybody confirm that it IS or IS NOT possible to turn off the little red indicator on the dash and the message in EVIC for the driver's seat belt?
You can only turn off the chime for the seat belts, you don’t need ALFA BDO for it
Link
Matt Franklin
Lexington, KY
Link
Yeah, I've got the chime turned off, I'd like to disable the other 2 functions as well. For eveybody who has said it's not possible, it seems like there are equal number of threads saying it might be, but I can't find any followup on whether anybody actually tried the settings they were contemplating and their results.
Evguy1
Errington BC
2014 RAM1500
Cummins ISB 170
I'll be happy to look at the log from 2019 Classic 5.7 Hemi later this evening if that helps you any.
That would be awesome. I think any Hemi should have the same Crank sensor readings.
Needs to be running when you read the file. :)
Evguy1
Errington BC
2014 RAM1500
Cummins ISB 170
Wow, that's nice to know, Thank You! I assumed it would unlock. Did you notice if the part where it says something about seeing 3-4 crank sensor pulses? Mine says NO.
Evguy1
Errington BC
2014 RAM1500
Cummins ISB 170
No problem, the unlock was what I was concerned about.
JC4041
Rosamond, CA
A couple of weekends ago I programmed 2 new FOBs for my 09 1500. Everything worked fine, drove around the block with the new fob in the ignition (originally I only had 2 keys). Parked the truck for the night, went out the next day and it cranks just fine with the aftermarket remote start (runs for the 15 minutes and shuts off like it has for years) BUT when I put the keys in (any of them) it runs for 3 seconds and shuts off. I've looked off and on all week, but I can't really find anything.... The remote start mimics the key freq, so I'm not sure if it's the keys that have gone rogue or if there's ACTUALLY something wrong. It's throwing U0236, as you can see from the Alfa screen shot, it's reading the keys....it's just not SEEING the keys in the ignition. I tried to find a wiring diagram, but the only thing I could come up with was for a 2012 Caravan (bodybuilder doesn't work and I tried downloading the service manual from the Z and I can't get it to open). Anyway, I figured the Caravan would be pretty close in troubleshooting and found (A106) FUSED B+ CIRCUIT OPEN.....but that's all I got to go on.
Minnesota
I found this online as I want to do a transmission relearn but am unable to connect to my gearbox to do this, any ideas either how to do a trans relearn without connecting to gearbox or how have some people connected to the gear box before?
bebop86
guys- Just changed my rear tail lights to Led on my 2015- Updated on AlphaOBD but still get parking lights out on dash- any ideas??
ScrappyDogg
Louisiana
It's located here if you want to try. Other people have vaguely confirmed it works and I'm trying to find time to install my LED fogs but if you have time, it would be nice to confirm and plus you wouldn't need the extra cancellers on each light if successful.
LED is under this section..
CBC Features Configuration:
LED Reverse Lamps Present: Not set
LED Stop Lamps Present: Not set
LED Rear Turn Lamps Present: Not set
LED Tail Lamps Present: Not set
LED Rear Fog Lamps Present: Not set
LED License Lamps Present: Not set
LED Front Turn Lamps Present: Not set
LED Front Fog Lamps Present: Not set
LED Dedicated DRL Present: Not set
LED Low Beam Lamps Present: Not set
LED High Beam Lamps Present: Not set
LED Front Park/Marker Lamps Present: Not set
VTA Hood Ajar Monitoring: Not set
TCSM Present: Set
Sent from my SM-G950W using Tapatalk
What is the tcsm present?
sscamaro1968
mo
Can anyone tell me how to get the ram 3500 splash screen on my evic.
Its a 14 3500 ram , i upgraded to a 7" evic from a 15 1500.
I changed it in the special packages config 1 and 2 with alfaobd. But no luck.
I can however get all the longhorn, laramie, sport, bighorn , ext. But no ram 3500
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
Can I use the AlfaOBD to change the size of my fuel tank I'm thinking about installing a Titan 52 gals in my 2018 3500 and I have been hearing that I need a bypass can someone point me in the right direction to get setup?
kad
Hudson Valley, NY
5.7L HEMI
There are settings for the tank size, but I've heard mixed results on folks trying to get the changes to stick.
VehConfig 3:
___________________
Fuel Capacity (36-290 L): 98.000 Liters
The important issue to remember is that the capacity is in LITERS.
The above setting is for my truck's stock 26 gallon tank. 52 Gallons is approximately 197 Liters.
-K
Bigdaddy
6.7L Diesel Cummins
Oh okay so I see that you have the titan 52 gals how is yours doing? Hopefully when the 4wheel parts store install it that they will setting correctly.
CanRebel
Toronto
I have 33 us gal. mine shows 125.0000 liters
You do need bypass. I'm using Zautomotive SGB module
https://www.zautomotive.com/product/z_sgw/
They also sell cable, but it's pain to install it, for few dollars cheaper.
You also need something like OBDLink. I'm using OBDLinkMX+
JustinRam1500
