AlfaOBD
deane10
Cummins
I am looking to make some changes to my 2021 Ram 2500 using the AlfaOBD software. Specifically I would like to Auto-Fold the mirrors when in Park and Auto-Unfold when put into drive. I searched around and didn't see this mentioned anywhere. Sorry if I missed it. There is a tazer or something like that that does this by just plugging it in. I do not want something plugged into my OBD Permanently...
Thanks in advance for the help!
Jimmy07
Can’t be done with AlfaOBD. Look at it this way: the switch for the power folding mirrors is always hot, even when the truck is off. It is also inches away from your index finger when opening door after shutting the truck off.
Mike Harrison
Winnipeg, Manitoba Canada
5.7L V8
2010 ram i understand if i enable Police Lighting Feature ill be able to dim my cluster display down to almost nothing , but it will also disable the locking power doors , is there a way to have cluster/dash lights dim more then regular while keeping the power locks enabled ?
joelmic
stl mo
2017 Ram 1500 Express Quad Cab 3.6L 4x4 20x9 Wheels
I forgot how to get to the battery reading in Alpha...
Some readout told you when it was getting near it's life end???
Warmage
i got another 1500 2021 classic reg cab , will alfaOBD work on it ?
i want to add
1 signal/heated/power folder mirrors
2 auto dim rear view mirror
3 remote start
4 audio controls to steering
5 sun visor with lights
Golfanatic
GA
Hemi V8
Hello! I am new here and honestly just want to borrow an AlphaOBD app and OBD scanner from someone in GA. I just installed the OEM brake controller so I can pull a camper and I called every dealership and they want $150-$175 labor to change the below 4 settings...
ALFA OBD Selection menu
CustSet menu 2 - Trailer Selected CSM
CustSet menu 2 - Trailer Name CSM
CustSet menu 2 - Trailer Type CSM
P/T Chassis Net - ITBM/HWM Integrated Trailer Brake Module
Anybody local and can help me out?
marine6212
Where at in GA? I'm in Houston County.
SeppW
Northern VA
Hemi 6.4L
i want to add
3 remote start
I don't think so, but could be wrong. I've seen posts where it does with marginal success. Post one on this thread has info. Could google Alpha OBD and ask the developer, he's pretty responsive.
Warmage
already regretting getting this new Ram
SeppW
Northern VA
Hemi 6.4L
items 2-4 should be able to do w/o Alpha OBD. Not sure about factory auto-dim mirror, but the should okay with install all it needs is power. May not do much if rear glass has heavy tint; dealer can install MOPAR remote smart kit, surprised they didn't try to sell that along the add-ons they try to sell while waiting for whatever they're doing in the back office; MOPAR has kits for the steering wheel controls, check availability for MY, but will work with UConnect 5.0, 8.4A and 8.4AN, not sure if you have the big 12 in screen; sun viosr with vanity lighting could be a little leg work. Depends if the harness is already installed (tucked up under the headliner and will have to pull it down to some degree to check, otherwise you'll have to wire up some leads and tap into power somewhere; likely need alpha OBD for folding mirrors, plus all the other stuff. The factory powered mirrors aren't cheap, need to pull the door panels and see if you have, or need, the right modules, and the switch panel, etc. Couple of aftermarket sorts, like Infotainment, sells kits too; pricey though.
Warmage
yeah i already replaced power folding(towing) mirrors on my 2013 , but it already had OEM one to stat with
for the 2021 looking at it , i need the switch,modules and programing and hopefully wires are already there
remote start they want to charge $1100
planing to sell the truck with only 240 miles on it , and get in line for a TRX
SeppW
Northern VA
Hemi 6.4L
$1100 for remote start? The kit is like $200+. Dealer offered to throw it at no cost if I would buy the undercoating "deal." No, no, no, no! Good luck on the TRX. I'd like to have one the Hennessey TRXs, but just don't have the kind of money. Trucks are already astronomically high.
Sking80
Atlanta Ga
What part of GA? I’m in Dekalb County
itzmillertyme
Ontario, Canada
Does anyone know if you can get 1 touch window "up" feature for a ram regular cab? I know these are only set as auto down. Just wondering if there's a mod for the 1 touch auto up
Sking80
Atlanta Ga
Nope safety thing I guess
BigJoe1094
Somerset County, NJ
Hello all, anyone know if its possible to program out the 'parking light out' alert? i just swapped in a 7" EVIC and it is going non stop (all light options are set to LED and are functional)
Sking80
Atlanta Ga
Have you check all of the settings are enabled for led in the status Id check just to make sure? I had that issue and I thought I changed them all but the bcm didn’t take 1 of them and I went back and RE enabled it and the alert message went off
BigJoe1094
Somerset County, NJ
I can always double check to make sure they took. Any chance you remember which one caused the issue?
