AlfaOBD
John-Dennis
Houston
I want to find two circuits to activate a pair of relays. 1. Ignition on and 2. Engine on. I am also wondering if AlphaOBD will activate any "Upfitter" options on a 2016 1500
UK1500Ram
Preston Lancashire UK
Hi all,
still working on getting my damaged Ram back on the road… I thought I was nearly there with the work, but found a hidden damage on the casting of the EPS steering rack, which means it needs total replacement.
I have ordered a rack from a supplier in Europe but I am wondering about how to code it to the car once it’s been fitted?
can I use AlfaOBD to do this? I have been searching in the forum without success.
if it’s not possible with Alfa, is there a reasonably priced scan tool that you guys recommend that can recode the new rack?
thanks in advance,
G-Ride990
Administrator
Administrator
Chandler, AZ
Hi all,
thanks in advance,
These are the only options I see in steering. I am not connected to my truck though so maybe more will popup if I connect to it.
BlownGP
Houston/Baton Rouge
So I'm probably beating a dead horse here. I've scrolled on a few pages here out of the 1388 pages and I'm still at a loss. I've researched and watched videos, went through the app trying to figure out what's going on and still lost. I'm sure MANY people have had the same issues and got them resolved and I'm hoping someone can either point me in the right direction or help me out. I've got a 2015 ram 1500 tradesman 5.7l hemi. Changed all bulbs to LED's. Brake lights LUMINATE when I hit the brakes but the "running" lights won't come on. Had resistors connected but since removed them. Had the hyper blink going for a while with the light out message, but once I changed to the LED option in the app, that all went away. How do I get BOTH to work? The brake running lights along with the turn signal lights? Reverse lights work fine. My headlights work everyone in a while. When they go out, they flash on and off 2-3 times and then stay off. That is completely random. If anyone has the quick fix and don't mind beating a dead horse with me, I would greatly appreciate it!...
You tired flipping the leds in the socket? Do they have two metal connectors on each side?
PlainsmanND
Just wanted to share gratitude for this thread, all squared away.
For what it's worth, I didn't experience any issues with the BAFX tool I had in the chest. Deerguys cable is nice. And much thanks for the writeups and information guys!
2018 6.7 Laramie Crew
Matt Franklin
Lexington, KY
I own a 2013 tradesman and am looking for a way to activate the keyless entry for it. Has anyone does this yet with AlfaOBD? Dealer says it is just a sales code they could add to activate it, so I decided to ask here first. Thanks in advance for any help
Were you able to find your answers? There are other threads here specific to adding RKE. There is some hardware that needs to be updated and some wiring that likely needs to be added. There are a lot of variances between different years and trim levels, but essentially, what's required is: hood latch with switch (may already be installed), wiring from hood latch to Power Distribution Center (PDC) (wiring may already be installed), wiring from PDC to Body Control Module (BCM) (wiring may already be installed), new Radio Frequency Hub (RF Hub or RFH) (RFH may already be installed). There are kits on Amazon that contain all the hardware and wiring, but there are more cost effective ways to get it all. After all of that is good to go, you need the 4 button FOBIKS (can buy 4 button overlays on Amazon to use with your existing FOBIKS), you'll program the new FOBIKS using AlphOBD, then change the appropriate settings.
Those are the hardware pieces and the major steps required. Like I said, there are other threads here that go along with this one to provide all the details. Youtube is also your friend for this upgrade.
Justin33
I cant figure out why I can get my turns to operate as drl. I thought I changed everything in Alfa so can anyone tell me what I have done wrong?
kad
Hudson Valley, NY
5.7L HEMI
I have a 2014 and I've had mine set for a couple of years. Here's all the related settings on mine:
Code:
CBC Config I/O:
    Right Dedicated DRL Lamp/Right Signature LED Present/Right Front Turn Signal #2/Headlamp Leveling Output Present:  Yes
    Left Dedicated DRL Lamps/ Left Front Turn Signal #2/Left Signature LED Present :  Yes
CBC Features:
    DRL Configuration: Optional DRL
    DRL Lamp Location: Dedicated
    DRL Dropout Enabled:  Yes
    LED Dedicated DRL Present: Yes
- Note: I have factory Projector headlights with LED turns
ECUConfig3:
   DRL Customer Setting Option Present:  Yes
Cust.Prog.Features:
    Daytime Running Lamps:  Enabled
Cust.Set.Menu 1:
    Daytime running lights CSM Present:  Yes
-K
Justin33
Code:
CBC Config I/O:
CBC Features:
ECUConfig3:
Cust.Prog.Features:
Cust.Set.Menu 1:
-K
I have quads maybe I will wait until I make the swap.
Sking80
Atlanta Ga
Can the power side mirror turning lights be used as DLR?
kad
Hudson Valley, NY
5.7L HEMI
That may be the issue. On the projectors, you can't use the Low Beam DRL setting, it simply won't work. No one (outside of the manufacturer) knows for certain, but my therory is that it has something to do with the turn signals being the factory default for DRLs on projectors and the low beams the factory default for non-projector DRLs. I actually wanted to use the low beams on my truck, but couldn't.
-K
kad
Hudson Valley, NY
5.7L HEMI
Not as DRLs, no. Daytime Running Lights are always in the headlight area, by DOT regulation.
You CAN get kits that let you use the mirror turn signals as running lights though. There's at least two companys that offer the kits. They require some minor wire splicing and some rather tedious threading of wires through the door connectors IIRC.
-K
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
I have everything I needed coming so I want to be able to run in my tail light LED's bulbs and my head lights HID's, well I have the HID's projector headlight but if I can get rid of the resistors will be great, do you have an how to so I can go and change all of this?
ManualCummins
Cummins 6.7
I have done it several times it's super easy if you need some help send me a message
Bigdaddy
6.7L Diesel Cummins
Okay guys I'm getting my bypass cable and my obd MX+ sometime soon and I want to do this one at a time, so I install a 52 gals Titan fuel in my 3500 and I want to see if I can use my setup to change it to read 52 gals, now I believe I change that to 194 liters, is this correct?
CanRebel
Toronto
52 US gallons to Liters should be 196.8 or 197 rounded up.
twhiteside
Mt Airy, MD
Cummins 6.7
Please post if it works for you! I tried to change it on my 2018 and successfully made the change, however the fuel gauge did not read correctly so I changed the value back to the stock setting.
Bigdaddy
6.7L Diesel Cummins
Okay will do, so what was the stock setting then? I'm waiting on my bypass cable now I was thinking to just leave it alone but I will at least go and see what's the reading.
JC4041
Rosamond, CA
I can't remember in which AlfaOBD thread I saw it or it could have been in the fuel tank thread, but I remember seeing something about the truck not being able to recognize the "full" 52 gal (or liters) values and to go a little lower. I just can't remember which thread it was in.
