Alignment question
blu3s94
I have bilsteins set at 2.1 rite now, I was going to set them to 2.8 saturday and install 1.5 inch steel spacers in the rear. I ordered mevotech UCAS but carid screwed up my order and I wont have them in time when I do all this. I was also planning on having an alignment done this same day but should I wait until the new ucas are installed or will it not change my alignment to just swap ucas? Thanks
Sent from my SM-G920P using Tapatalk
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
You definitely need to wait until the new A-arms are installed before taking it in for an alignment. The alignment is adjusted with the bolts that hold the A-arms to the frame.
Jameson
Fort Benning, GA
When I installed my crap it seemed that there was no adjustment or cams on the upper control arms. All the adjustment was at the LCA and TREs...from what I could tell. Other trucks I'm used to the camber etc being adjusted by the UCA but these don't seem that way unless I'm a *******..which that has been the case many times.
B
blu3s94
Ok thanks
