AlphaOBD Question
drewdiesel12
Sacramento, Ca
Hey everyone, I have a ‘19 Classic and my truck came with the 8.4” faceplate with the standard 6 speaker stereo (non alpine). I just bought the factory subwoofer (mounts under back seat), plugged it in and it’s not working. My question is, will an alphaobd work with my year truck, and it’s there a setting to unlock and sync the sub to my current sent up. The sub came with the alpine options but I feel like it should still work because the truck was wired for the sub from the factory. Any help would be great! -Andrew
Mordechai
St. Pete, Florida
You'll need the factory amplifier as well, might need to change some wiring around as well. AlfaOBD can change the settings of the truck to read the amplifier.
Sent from my ONEPLUS A6013 using Tapatalk
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I would use an aftermarket amplifier for it. It's not plug and play if your truck didn't have the Alpine system.
I would also replace the OEM sub itself with something else.
mtnrider
Georgia
Yeah, not that simple. You would need to add the factory amp, re wire everything etc. Much better off going with an aftermarket amp.
mtnrider
Georgia
So I could get an a/m amp, that’ll work with my oem radio & the oem sub?
Yes, You'll need one that accepts line level inputs and of course splice it all in (or get a harness to break out the lines), nothing is going to be plug and play if that is what you are looking for
hunterjohnson93
