The Amp pro features are overkill by allowing multiple amps, but for even just subs, Is best. The Amp pro takes the oem headunit signal before any processing, then sends it out to rcas. The LC2i installs after the amp/dsp so the amp/dsp interferes with the sound and on top of that rolls off the bass as the system is turned up. I found a open box amp pro for $140 on Amazon and been happy with. I also tried a pac line level converter, the lc2i and a ax-dsp, all except the amp pro had issues. The LC2i would add a odd processed sounding bass or would random be louder, bass rolloff still happened and I could ever get the bass to have a clean sound, to me sounded processed. The ax-dsp sounded excellent and installed just like the amp pro, but was plagued by a bad app, I was able to get the ax dsp app to accept I had the amplified system, then would go into the app to make a new adjustment and app would revert it to the non amplified system, so I had zero bass control and had to turn it up or down using bass knob. Which sucked, if wanting to turn down radio, I had to turn radio and bass knob. After like 20 emails to customer service, multiple firmware updates, app installs etc it never would work right. All customer service said was, get a iPhone or apple tablet, it has issues on android. Then right after that they came out with a newer version of the ax-dsp.
