another HID flickering problem
yamaha73
so ive got the same problem as usual with flickering
ive done hids before and never ran into this problem if i would have known i would have just bought them from JJ like everyone else says
so i bought the cancelers i believe with the capacitor and it still didnt work same problem, do i need a relay harness? and is there anyway i could make my own relay harness because i dont feel like waiting another week for one to get to my house since i hard wired my hids?
also i got leds for my parking/blinker is there a way to make them so the truck doesnt think the bulb is out and blink really fast
thanks!
Royce
LB3711
Trumbull, CT
3.6L V6
Make sure the ballasts are grounded to metal. I had to ground the negative wire of each ballast to metal at the ballast to stop my flicker. The relay harness carried the ground back near the battery instead of right off of the ballast.
Sent from my tapatalk equipped AT&T iPhone 5
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Need more info on how this is wired. No relay harness? hard wired? rut roh...
For the turns, get some 50w6ohm resistors and wire them in.
yamaha73
yamaha73
i dont have a wireing harness for them, just a plug and play kit with the cancelers but i didnt like how they connected to the actual headlight bulb plug so i cut and soldered the 3 wires (ground,high,low)
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I really can't see that working well, even with a bunch of resistors / capacitors, etc.
yamaha73
yamaha73
well all i did is instead of having a plug i have them wired together idk wat the difference would be but i can put the plug back in no problem, or should i just buy one of your kits, and what do they run because i just want headlights again, im about to forget hids and go back to halogen for my headlights
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
What I mean is that I wouldn't trust them being piecemealed together. Cancellers really don't cut it.
Are you doing a bixenon kit or hid low / halogen high?
Yeah, I'm not going to turn away an order.....lol - our H13 bixenon sets run 165 shipped in the states. Thats for the harness, bulbs and ballasts - everything needed for your truck.
yamaha73
yamaha73
got it, yea this is my first dodge and if i would have done my research to begin with i would have just bought them from you because now im in my kit 140 bucks and its useless to me, but im running the hid low and halogen high, i wont even use the high beam because for my high beam ive got an led light bar i can use lol
this is the kit im running http://www.amazon.com/gp/product/B00DLMPM5W/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
yamaha73
yamaha73
if i ran the relay harness you guys offer would that work do you think or no
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
if you are running that kit, we'd need to do a special harness for them, we don't stock a HID low / halogen high setup. Will need to dig into what is required on that again here.
yamaha73
yamaha73
well heck for all your help ill just get a whole kit from you, should i go to your site or pm you
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
I will be ordering son the relay kit from you. I have a set of Philips Hid lights and balasts and they worked for a while but now the passenger side goes out on me sometimes. Replaced the relay but still shuts off. Not sure what the problem is I thought that I had it fixed.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
best to nab it off the site. Quickest, easiest! ;)
Argh! there are SO many things it could be.....damn electronics!
MegaMouseGW
South Louisianna
Ordered the harness, but I think I screwed up when I made my account. Sent a message to you by way of your contact form. It was late when I placed the order so I most likely typed the wrong e-mail address. Will not even let me log in and when I use the password recovery it says my address is not registered. Hate when I do stupid things like that.:imo:
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I got ya all fixed up ;)
Crapo85
