ScubaSteve42
2012 Ram 1500, Vararam Intake, Magnaflow exhaust, unknown tuner (previous owner).
I've been nervously waiting for the day that the lifter failure would come, but finding some solace in the fact that it seemed more prevalent in 2011's. Add that with an intermittent CEL over the last year or so pointing to an fuel evap sensor (not sure if that is the right name... something about air leaking from the fuel tank or cap).
Then I had a light that wouldn't turn off after a new tank of gas... P0306. Took it into the shop, hoping for plugs, coil, or injector failure... nope. Cylinder 6 was holding 50-60 psi, while I think the others were around 110. No word on the cam yet, but the mechanic wants to replace both head gaskets, timing cover gasket, machine the heads, and replace both lifters on the right side. $3,119.
Quote seems high, but I'll shop around.
My question stems from this thread https://www.chargerforums.com/threads/firing-order-of-5-7-hemi.132390/
Firing order for the 5.7 is 1-8-4-3-6-5-7-2 and w/ MDS 2-3-5-8. If 1, 4, 6, and 7 are deactivated, does it makes sense that the #6 would fail? Is it BECAUSE it is deactivated?
Last question, is it bad to hope for a worn cam so I can justify dropping cash on a new one? Any recommendations?
