Beasley907
So I got a couple antifreeze testers from the store. The one with floating balls gave me wild readings. So I got a Preston one and that says I’m good until -7. So if this is accurate that’s obviously an issue in Alaska. My cooling system is just over 4 gallons so I was thinking about draining a gallon and adding a gallon of concentrate to bring it to or close to the minus 34 rating of 50/50. Will the system mix all that concentrate good enough to not cause problems?
2015 ram 1500 5.7
2015 ram 1500 5.7
