Antifreeze tester
Beasley907
Wasilla, AK
Are these little chaslyn antifreeze testers any good? I felt it was giving me different readings every time. I averaged it out to about 3 balls floating per test. So basically I’m protected to about -10. So not great for Alaska. So I drained about 2 quarts from the radiator and refilled with 2 quarts of concentrate. Am I on the right track? I’ll retest tomorrow but hopefully I’m good after the adding of concentrate.
Dean2
Near Edmonton
I still use a Prestone supplied version like this. I find them a lot more accurate than the ball type. I mix 70 coolant/30 water to get max freeze protection.
(Max protection for most Glycol is at 60% glycol to 40% water but I like the extra glycol just in case I have to add water on hte road and have no mixed or glycol to add with it.)
Dodge 1500 4X4
Rochester, NY
Yes that should bring it down with the concentrate formula, put that in the radiator.
Beasley907
Beasley907
Wasilla, AK
I picked this up this morning gonna test it on a pre mix 50/50 to make sure it’s somewhat accurate so I have a base when testing my coolant in my truck.
srv1
blasdell n.y
345 c.i. HEMI MAGNUM
If I remember correctly,after I refilled with 50/50 mix I had to swap in about 1 gal. of conc. to get to proper mix due to the distilled water left in the motor after the flush. Refractometer,$20.00.Peace of mind when it's 0 degrees,priceless.
LouM
Marine Corps
Greeenwich/Easton upstate NY
2015 Ram Ecodiesel crewcab old/ 2019 Laramie Hemi old/ 2022 RAM 2500 6.7
eco diesel old / now Hemi missing the eco's mileage/ now back to enjoying diesel torqueesel
The "new" style Refractometers are the best way to test our new OAT and HOAT coolants
Beasley907
Beasley907
Wasilla, AK
Yep just tested the 50/50 mix with prestone tester and it’s accurate. So I’ll go ahead and drain a gallon out of the radiator and replace that gallon with concentrate and see what happens
