- Joined
- Apr 28, 2012
- Posts
- 27,717
- Reaction score
- 58,131
- Ram Year
- 2010 Hemi Reg Cab 4x4
- Engine
- Hemi
Sea Foam through vac lines, that product doesnt do much in a gas tank but wonder through combustion chamber. It is a very weak solvent, I believe just alcohol, no reason to add that to gas tank. You can do the red tube or just spray it into throttle body.
youtu.be
youtu.be
Does Seafoam Actually Work in a Car? (with Proof)
In this video I test Seafoam in a Honda Civic Si. I use a mini borescope camera to look into the engine and see how dirty the engine is before the fuel treat...
Seafoam - Engine Treatment | How-to and is it safe inside your motor?
Does seafoam actually work? Is it safe inside your engine? Should you do the full seafoam treatment and how do you do it? My 1994 Bronco 5.8l has 150,000 mil...
