cam and lifters
  1. N
    Easier to pull the oil pan on a lifted 1500?
    I’m looking for anyone with any experience doing a cam and lifter replacement on a lifted 1500. My 2015 4x4 is lifted 4” with a kit from rough country and it’s going to need a cam and lifters at some point soon. I’m most likely going to swap to a high volume oil pump with non mds lifters and...
  2. M
    Closed loop fueling and O2 sensor codes after cam and lifter replacement.
    Just finished cam and lifter replacement on a 2014 and now I’m getting codes for both my downstream o2 sensors and it won’t achieve closed loop on both banks. It starts and runs good and I used a scantool to confirm my timing and it says everything is fine there. The only thing I noticed is...
  3. P
    2020 1500 Hemi Tick Please Help!
    My 2020 1500 5.7 hemi is ticking and I can't figure out what it is. The truck has 59,500 miles on it and less than 450 idle hours. There is a loud ticking noise during idle, cold and warm, and it also matches the RPMs. I took it into my local ram dealership and they replaced both exhaust...
  4. T
    2021 5.7 Hemi already getting a top end rebuild, good to go or time to move on?
    My 2021 Hemi is getting a new cam, phasers, and lifters at 49k miles. Lucky for me the warranty hadn't run out yet. Everyone is telling me to tuck tail and sprint away from this truck the second it is out of the shop. Should I be genuinely worried about the rest of the engine going to crap, or...
  5. T
  6. tx1500ram
    Cam lifter 2012 ram 1500 5.7L hemi
    My ram 1500 is at 135k miles, everything is solid on it especially the transmission and I just replaced the spark plugs and all the coil packs, I just got a quote for the camshaft repair and it was 8000 exactly. Is it worth getting the repair or just buying a new engine or trying to do it...
  7. D
    2013 5.7 cam lifter replacement complete…No crank No start…will crank if starter relay jumped
    2013 Ram Hemi Sport 4x4 with push button start and 8 speed transmission ~91k miles. I bought the truck running with the Hemi tick…the tick was caused by broken exhaust studs on both heads and cylinder 8 lifter failure. I took almost a year stripping the engine down and replaced cam, lifters...
  8. D
    Motor sounds/runs awful after cam
    Yesterday I finished my cam/lifter job, and the motor sounded awful, all sorts of ticking and a ton of shaking. Even after a tune it wont idle much. Also to note I had a p0108 and the red lightning bolt symbol was flashing like crazy, which I believe is the throttle body. I believed it to be a...
  9. A
    MDS delete
    I’m thinking about doing the MSD delete from ams racing with the stage 2 Texas speed cam and getting the Melling 10452HV has anyone done this or have any tips? How’s the mpg and how much power did it add? 09 hemi 4x4
  10. B
    An introduction, a thank you, and a request for advice.
    Firstly- a big thank you to all the fellas (and ladies!) on this site. I just, and with limited mechanical experience, completed a cam and lifter job on my 2012 Ram 1500 Big Horn with a 5.7 Hemi. Probably could not have done it without being pointed to this forum. I found lots of helpful tips...
  11. Y
    (Help)Ams MDS and tuner kit
    I am not no professional just trying to make my truck run better. I just bought AMS racing MDS Delete and tuner kit that come with the Mopar lifters. I’m overthinking what other parts I need to buy. Do I need to get the Melling Oil pump, new timing chain, new Valves , and new push rods? I just...
  12. J
    Any and all advice welcomed …
    Greeting fellas Ran across this forum multiple times (unfortunately and thankfully) here recently. Just looking for tips and advice, it will be greatly appreciated. I have searched multiple threads on here and gathered great information on how to move forward so TIA for that. Here’s the back...
  13. L
    P0301 Help
    I have a 2011 Ram 1500 SLT 4WD 5.7 Hemi with 183,000 miles. These are all the codes I have currently: -P0301 cylinder 1 misfire -P0456 evap system leak (I have a small exhaust leak so self explanatory) -P0153 O2 sensor 2/1 slow response -P0133 O2 sensor 1/1 slow response -P0430 Catalyst system...
  14. B
    Austin Tuner
    Anyone know a good tuner in the Austin or Killeen area? Currently doing an MDS delete and need a tuner for once I've got the thing rebuilt. Thanks!
  15. B
    Cam choice for MDS delete
    2012 1500 5.7 Pulled my cylinder heads off and confirmed cam/lifter failure. The block is good so I'm moving forward with a rebuild. Planning on doing MDS delete. Currently trying to decide if I should get a stock non-mds cam or a TSP Stage 1. Are any other modifications needed to a stock...
  16. B
    2012 5.7 Engine Failure
    Howdy, y'all. A year into owning my 2012 1500, 5.7 Hemi and the engine crapped out. I'm suspecting it's cam and lifter failure. Cylinder 3 misfire after replacing all spark plugs. Technician found gunk (oil and carbon I suspect) built up on one side of cylinder 3 and a 120 psi pressure. He got...
  17. Gilberts Garage
    New Camshaft recommendation?
    Hey ya'll I'm new here, but have spent hours reading threads. I've been a GM/Chrysler tech for the last 13yrs so I have loads of experience in replacing parts. I've always replaced with oem parts, never installed a "performance" camshafts before. I have a failed lifter 4 weeks after buying my...
  18. L
    2014 Dodge Ram 1500 5.7 Cam Kit ?
    I’m new to this forum and I’ve got my 2014 ram tore down to nothing but the block and I’ve been scrolling and scrolling and I just can’t narrow it down to what I need, but I’m looking for a simple cam, lifter etc. kit to install. Anything is helpful and thanks in advance!
  19. 1
    Best cam upgrade for a 360 Magnum
    Hi all, I currently have a 318 Magnum in my 1998 Dodge Ram 1500 2wd. At some point Im planning on installing a 360 magnum, because why not. I figured while the engine is out, i could do some internal work then. I'd like a cam that gives a nice performance boost, but also something that I can...
  20. L
    MDS issues after cam and lifter swap
    Good morning, I recently had the cam and lifters swapped in my 2013 Ram 1500. After getting the truck back from the shop it lasted about 50 miles before having a severe misfire. Pulled the code P1414 so I pulled and replaced all 4 deactivation solenoids. Truck ran fine while in tow haul but...
  21. B
    She’s lived a long and adventurous life
    I’ll be Ramin or Dodgin until I die. Grew up bouncing around in a loud 24 banger ask my grandpa to flip to the B side of “The best of ZZTOP” bought my dream truck with 24,000 miles on it. 2013 Ram 1500 Laramie Longhorn. She changed my life, freezing my butt off just to lay my hands on her warm...
  22. tscarber
    No Codes, No Start
    Recently I have replaced the Cam / Lifters in my 2013 Ram 1500. I replaced cam, lifters, oil pump, water pump, sparkplugs, cam position sensor, VVT solenoid, cam phaser, timing chain & accessories. Upon start up the truck will not run. The truck will turn over with no issue but will not run. I...
  23. RAM208
    Rough start-up
    14 Ram 1500 with the Hemi, all stock besides Cold Air Intake and exhaust. For the past few days upon start up the truck idles rough for a few seconds before "coming alive" like normal. It almost sounds like the truck is cammed when it first starts. No check engine lights, nothing. It last for a...
  24. ews25
    Anyone running Vararam-cam kit-shorties?
    New guy here. My 2011 Outdoorsman 5.7 is in the shop right now with a potential valvetrain failure. P0300 and #5 is zero compression, apparently. If that's the case, I'm contemplating MDS delete cam kit with shorty headers and a Vararam intake. Is anyone running that combination?
  25. H
    Piston slap?
    So I have a 2013 ram 1500 5.7 hemi, I replaced the manifold which was ticking and then there was another tick so I brought it to the dealer and they said it was an internal engine noise, a piston slap. Said the pistons are slapping up to the cylinder walls. I figured bringing it in there that it...
