Anyone Have These Fogs??
tidefan1967
Summerville, South Carolina
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Just bought some of these a few minutes ago: https://www.amazon.com/gp/product/B089CRNSH6/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
There's now a 22% off coupon apparently that wasn't there the last time I looked. It knocked $28.60 off the price so I took the plunge. Hopefully the same discount is there for anybody else that was on the fence. Pretty sure you have to add them to your cart to even see the discount. Good luck!
Looks like it's only for the chrome sets too. Good info!
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
and the z-offroad versions are functionally worth it?
shadowhawk
Southeast WI
Alpharex headlights and z-offroad series foglights. You can get both from amazon but i suggest going through alpharex to purchase headlights. They are great to work with and very helpful.
how do you like the z-offroad fogs?
LoadedExpressRam
Gulfport, MS
They seem to holding up nicely. My only complaint would be the fitment on my sport bumper(may be better on other bumpers or worse i guess) the gap between the bumper and light lens is almost double from that of the factory light. Its not that bad where anybody would notice but im sure other ram owners would. Other than that no complaints. They are bright and no moisture thus far.
LoadedExpressRam
Gulfport, MS
Dont let me discourage you. Like i said its not thar bad. Ill try and snap a pic when i get home. You can compare that to your factory ones.
shadowhawk
Southeast WI
and you had no trouble aiming them? do they bounce like the factory versions?
shadowhawk
Southeast WI
I bought a set. My issue is I broke 1 mounting point on the truck side, same point on each side. Speed nut got bound up and just spun the plastic on the mounting right off the truck
Sinistre1
They are a prime day buy today. Bought a pair. 103.99. Will see how it goes. I echo someone in this thread sentiment. I need to stop reading. This forum is an expensive read. I literally just bought a set of 4 way yellow/ white LEDs for the stock fog housing. Will decide whether to return or hold them
shadowhawk
Southeast WI
well, crap... could have saved $20. Oh well.
Sinistre1
Yeah I just got lucky. I was reading this thread.. popped over to Amazon for a look se and pow!!! They are a prime day deal. I considered it to be sign
VelocityC6Z
Maryland
I bought these yesterday as well. I noticed the prime day deal, and couldn't pass it up.
MidnightSVT
Oregon
5.7L
Purchased them a few weeks back when Amazon had them on sale (I think the same prices as on Prime Day?). Got the chrome version to match my chrome bumper and grille. Very easy to install, took about 15 minutes per side (being careful not to scratch the lens) and did not need to lift the truck. No errors in the dash and they are instant on and off.
Sinistre1
Those things look downright nasty in the bumper. Very nice! I hot the black ones for that stealth look!
MidnightSVT
Oregon
5.7L
No fitment issues with mine. They are tight with the opening of the bumper and don't bounce when the truck is going down the road. I still have the halogen quad headlights and the LED fogs almost overtake the the halogens in output!!
14Deebo
Arkansas
Just scooped these up and installed. They work great and look good. Only issue I have is that they shake a bit at idle. My truck is cammed, so the shake probably wouldn't happen with a stock motor. I can see them shake a bit when I hit bumps, but I had my wife drive it down the road and couldn't tell it was shaking from outside the truck, so IDK. I did the zip tie trick before I installed these, so not sure what else I could do to tighten them up. The shake may just be due to the design of the vertical adjustment, but they work well enough and look good enough to not be a deal killer for me.
Sinistre1
Will be a while before I can get mine on the truck. Hoping they fit without gaps/shaking.
Sinistre1
In the box.... having some second thoughts about the black. Hoping it doesnt limit output by not focusing the light
