Anzo headlights not working 06
Beauner
Bought and installed these years ago with the bottom 4 lights not working said f it didnt care. Now the low beam went out on the right, so i thought until i went to disconnect. As i applied pressure to pull apart the connectors, the low beam and the bottom 4 lights came on. Let go and both off. Parking, turn signals and halos around the beams work. Replaced connecter thinking that would fix it negative. All help is appreciated.
Dredger
SE Ohio
That tells you everything you need to know. There's something wrong at the connection - either on the headlight side or truck side.
Nick@GotExhaust
Supporting Vendor
SC
What did you use to replace the connector? You absolutely have a loose connection somewhere.
B
Beauner
only replaced connector not the wiring. Was trying to avoid that but that might be the next cheap move.
