ATF in Gas
bendirkss
Canada
Has anyone added some ATF to their fuel to fix the hemi tick?
Etroze86
Grand Forks ND
This will have no effect on the parts of the engine that are ticking. I have added it to oil in older vehicles to loosen up stuck lifters but its not something that I would recommend doing all the time as it is kinda a bandaid for a bad lifter.
bendirkss
bendirkss
Canada
Ya I'm thinking about doing it just once. Just a litre to a full tank
Sent from my SGH-I337M using Tapatalk 4
Etroze86
Grand Forks ND
Do not put ATF in your fuel it isn't made to run through injectors.
Chewy
Bettendorf IA
V8
Take a video of it if you do! I want to see the smoke! Not sure how much your cats will like it either.
bendirkss
bendirkss
Canada
Lol I'm not for sure doing it. I'm seeing what other people say. I kmow it was ok in older vehicles but modern engines are a little different
Etroze86
Grand Forks ND
Modern engines are a lot different. Smaller injectors than the old TBI's, hell I wouldn't even run it through a TBI maybe a carb if I knew it was gummed up and didn't have time to take it apart and clean it right. Just look at your truck, is it worth the price to fix other problems down the road that come up from putting something in your fuel that isn't supposed to be there? I don't know many 19 year olds that can afford a grand for new cats or the same for new injectors and I don't wanna play off your age but just look at bigger picture.
bendirkss
bendirkss
Canada
Your absolutely right. Im not saying im doing it. I strictly posted this cause I know it can be done and some people think it works, and I wanted more opinions and wanted to know if anyone has done it in a 4th gen and had success
Chewy
Bettendorf IA
V8
I've NEVER heard of doing it in the gas though... Only the oil or I've seen people squirt some in the intake to find exhaust leaks.
bendirkss
bendirkss
Canada
Burla
2010 Hemi Reg Cab 4x4
I actually have heard many guys run ATF in the oil before an oil change to clean it out, are you sure that is not what you are thinking about? Because there are a lot of ways that "could" work. Number one it would thin your oil and thin oil helps lifters. It could also clean away junk from lifters, another good possibility. However, on 4rth gen's we are already using the thinnest oil available that many brands make, so it would have less chance of working in a 4 gen then someone who runs 10w40. ATF is a great cleaner in engine oil so long as you don't run it for a long time.
Hornet
Banned
Diesal fuel used to be another cleaner guys flung into the oilpan then did their oil change.
Used to be high detergent contents in both,not sure where they rate now though as far detergent content
Diller
Nashville TN
6.7 HO Cummins
I think you are better informed now but I know some people use ATF in diesel fuel to help lubricate injectors. Gas engines work totally different and do not have near the fuel pressure to squirt the ATF mixture through injectors. You do not want ATF in your gas...at all.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
Early 90's fuel injection systems (Ferd) would go air bound in hi temps. A small amount of ATF (< 4oz) in the fuel tank kept the gas (or gas & alcohol) from flashing to vapor and binding up the injection system. '00 and newer systems do not vapor lock so ATF in the fuel would just cause varnishing of your exahsut valves or worse, Cat overheating and accelerated aging.
