Audio build
snipermax86
Tipton, Indiana
I started my audio build.
Here is what I got and some pics.
Head unit: Sony DSX-S310BTX
Amp: Pioneer GM-D9605 5-channel
Sub: Rockford Fosgate P3SD4-10
Speakers: x4 Rockford Fosgate R169x2 6x9
x2 Kicker 43DSC3504 3.5" w/ 600 Hz blockers
Wires & Mics.- KnuKonceptz 4-channel & 2-channel Krystal RCA cables
4 gauge wires going to amp and 16 gauge wires to speakers all for Ennis Electronics
Xscorpion digital positive battery terminal
RF distribution block & RF ground battery terminal
Noico sound deadener
S
snipermax86
Tipton, Indiana
Some pics of my build
S
snipermax86
Tipton, Indiana
More pics. Added foam baffles to all speakers. Had to add spacer rings in the doors for the 6x9s to fit right then put foam weatherstripping around speakers.
S
snipermax86
Tipton, Indiana
Tied in a mini 100 amp ANL fuse & holder. I don't have pics but all wires and cables are techflexed and zip tied to existing factory loom.
BadHabit2Break
Houston, Tx
3.6L
Looks very nice so far.
with a 5 channel amp, are you going to run the dash speakers with the front door speakers, or run the dash speakers off the headunit?
I am fixing to go down this road, but will be keeping the OEM headunit.
S
snipermax86
Tipton, Indiana
Yes I have the 3.5s running off the head unit. It's the only way to run the doors off the amp. Truth is it works well. Still got to get the sub box done and sub installed but system sounds good right now.
Jantelaw
