jumbalay35
hey been a while, so I just bought an AVS Lightshield deflector for my 2020 1500 Classic, I want to connect using a fuse tap. But I am not the greatest with electrical and this kind of stuff tends to make me nervous. I know the fuse in the engine are micro mini fuses, and tried to read up and watch some videos on YT. But none were very detailed or descriptive. So I do have few questions
I see the cigar lighter on the fuse diagram, its yellow rate 20amp fuse ( F93) , I would assume that would work as I want to have the lights to come on when the truck is running and off when I turn it off. Also , would I need the same amp size for the lightshield, or can I use a smaller one like a 15 or something? I also see power outlets ( instrument panel ) centre console) it too is 20amp Yellow ( F104). would those be the best options? I also see clearance lights and such, I cant find the DRL lights on there ( not sure there is even one for them?. ) One last thing and forgive me if this is a real dumb question. But does it make a diffirence between the colours of the fuse. Loike blue red yellow pink etc, If they are showing the same amps?
Any other suggestions where I can hook these up too? as I said I am mot the most knowledgeable guy when it comes to this kind of stuff. This is the one I have for reference.
Any and all helps is appreciated
Thanks
Thanks
