Axle weight limit
RamblinRod
Crawford, CO
2016 Ram 2500 CC LB 4x4
I know on the 2500 Cummins trucks the GVW is 10,000. Does anyone know what the axle limits are front and back?
crazzywolfie
under the truck
i don't think there is actually a set limit on the axles. they are not really like a set of axles under a trailer which have a rated weight. you pretty much just need to go by what the manual says you can haul in the box or behind you.
cptwing
The Soviet State of Connecticut
2014 3500 ST DRW REG CAB
6.4l Hemi
Rustycowl69
2001 ram 3500
V10
years ago, there used to be a decal on the driver's door jamb (B-pillar), which I pretty much ignored, but I believe it specifies just that.
Power247
High Point, NC
6.4 HEMI
My '12 2500 is rated 5500 lbs front 6000 lbs rear. But I guess that can be different depending on model year.
Sent from my SM-G900V using Tapatalk
R
RamblinRod
Crawford, CO
ManBOOYA
