osprey92
- May 1, 2017
- 151
- 58
- 2017
- Hemi 5.7
CEL is on, I pulled the above error. Analysis shows this related to the BCM (Body Control Module - TIPMCGW/FCMCGM). Am I correct in assuming this is the center brake light on the cab, and it is possible that the circuit board on the light has an issue? If so, easy fix with replacement. Or should I be looking eleswhere for error source (connectors, harness, BCM, etc.)? If it is the BCM, anyone have a part #for 2017 1500 Tradesman?
