Back camera issue
zeddy
Burbank, Ca
When I put my truck in reverse, camera was good, all of a sudden it got all distorted. See pic below.
While driving, I’d turn my camera on and it would get worse and worse. Then all of a sudden, it’s good again.
This last few weeks, I hauled a scoop of gravel, a lot of dust/dirt when unloading. This weekend, remodeling my bathroom, hauled the trash to the dump. Again a lot of dirt/ debris. Could dust get into the connectors? The screen is good. While it was distorted, the check surrounding warning was clear as day, seems like just the video feed was bad.
Any ideas? Thanks in advance. Also, my bumper to bumper warranty ended two months ago. Thanks in advance. d226b2759d9f686dc179ca60bce0be14.jpg
Administrator
Pull the connection at the tailgate apart and make sure it's clean. Reconnect and make sure the connection is tight
zeddy
zeddy
Burbank, Ca
i tried to pull the connector off but wouldn’t budge. I couldn’t figure out how because I couldn’t figure out if the two white strips were tabs or not. Didn’t want to break it.
bebop86
I had the same problem-I read that if you open and slam the tailgate shut it may fix it- I slammed it shut and yes it fixed the problem- worth a try- if not disconnect the battery negative cable for 30 seconds and reconnect-
RamCares
n/a
n/a
Hi, I'm sorry to see this. Please let me know if you plan on visiting a dealership for this concern. I would be happy to open a case for you.
Alison
RamCares
zeddy
zeddy
Burbank, Ca
Alison
RamCares
thanks, but last time I had an issue, my truck was at the dealer for total of three weeks. They said “we think we found it” but Issue was never fixed. I actually fixed it myself in my driveway at 10 at night. Took me five minutes. Doubt they even touched the truck but still billed you guys.
plus my 36/36,000 warranty is up.
rojo_143
Mine has done this from time to time ever since I had the dealership perform the recall for the tailgate opening. The most recent time it happened I was in my driveway and when I threw it is reverse my back-up camera looked exactly like yours, but when I back out of my driveway and hit the lip of my driveway to the street it when back to the normal image. I assume that I either have a loose connection or some corrosion on the inside of the connector. Luckily I am still covered under my 3/36,000 warranty so I just made an appointment to get it looked at. If I wasn't I would be opening up the tailgate and inspecting the connectors to the camera itself and also the wire going into the tailgate from the bed to make sure nothing was pinched or chaffed.
RamCares
n/a
n/a
Okay! Please let me know if you change your mind.
Alison
RamCares
RamCares
n/a
n/a
Was your dealer able to address this for you? Let us know via private message if you need any additional assistance!
Lydia
RamCares
